Gateway Checker Update
- News & Announcements
- Community Announcements
- Gateway Checker Update
Re: Gateway Checker Update
23-08-2015 10:38 PM
link3-central10.pcl-gw01.plus.net (84.93.249.164) 3.103 ms
23-08-2015 11:20 PM
Quote from: Riza Btw; I do have Safeguard on if this is causing the inaccurate findings?
Quote Posting the following information as a reply to the Gateway Checker Update topic in the Community Announcements forum will help us to diagnose the problem.
peer6-te0-10-0-8.telehouse.ukcore.bt.net (109.159.254.154) 6.247 ms
195.99.126.183 (195.99.126.183) 48.126 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 5.183 ms
ae2.pcl-cr01.plus.net (195.166.129.6) 4.650 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 4.744 ms
No, the occurrence of this message from the checker has no implications whatsoever on the performance of your router or line. The incorrect information could be likened to the wrong label being attached to the device. It's confusing but doesn't affect the device performance.
Correcting the information requires Plusnet to make what effectively is an administrative change to its "label" in DNS.
David
24-08-2015 8:48 AM
May I in ignorance ask, what the effects on internet use and performance of an incorrect rDNS is?
Quote from: spraxyt Thanks. Another instance of pcl-bng02 needing DNS updating.
David
24-08-2015 8:54 AM
Quote from: lucerne May I in ignorance ask, what the effects on internet use and performance of an incorrect rDNS is?
Quote from: spraxyt ...... the occurrence of this message from the checker has no implications whatsoever on the performance of your router or line. The incorrect information could be likened to the wrong label being attached to the device. It's confusing but doesn't affect the device performance.
24-08-2015 2:08 PM
Posted as requested
peer6-0-10-0-12.telehouse.ukcore.bt.net (62.172.102.25) 2.704 ms
195.99.126.183 (195.99.126.183) 2.673 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 2.926 ms
ae2.pcl-cr01.plus.net (195.166.129.6) 2.566 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 2.659 ms
CJC1942
25-08-2015 6:49 PM
David
26-08-2015 11:07 AM
Quote Sorry, the tool failed to identify your gateway; this does not mean that anything is wrong with your connection.
peer6-te0-9-0-10.telehouse.ukcore.bt.net (213.121.193.146) 3.320 ms
195.99.126.183 (195.99.126.183) 3.273 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 3.461 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 3.234 ms
27-08-2015 2:41 PM
David
29-08-2015 11:19 PM
peer6-te0-0-0-17.telehouse.ukcore.bt.net (109.159.254.140) 4.475 ms
195.99.126.183 (195.99.126.183) 3.037 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 3.124 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 2.999 ms
30-08-2015 12:02 AM
David
02-09-2015 1:53 AM
195.99.126.183 (195.99.126.183) 19.462 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 12.414 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 4.292 ms
02-09-2015 2:06 AM
David
02-09-2015 9:01 PM
ae1.pcl-cr01.plus.net (195.166.129.1) 2.279 ms
ae2.pcl-cr02.plus.net (195.166.129.7) 5.628 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 2.291 ms
wanting to check the gateway as have noticed on the ping graphs some packet loss last night 8pm-midnight, and looks like the same is happening tonight
02-09-2015 9:56 PM
Packet loss issues are best discussed elsewhere on the forums.
David
03-09-2015 5:01 PM
ae2.ptw-cr02.plus.net (195.166.129.5) 25.390 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 2.700 ms
link3-central10.pcl-gw01.plus.net (84.93.249.164) 2.709 ms
