Disconnects - Help Please
willcutforth
Fixes: 113
Re: Disconnects - Help Please
@superuser I have booked it in for tomorrow morning for you between 8am and 1pm is that all ok?
 Will Cutforth
superuser
That is fine. Thank you
willcutforth
Fixes: 113
I'll get back to you tomorrow afternoon Smiley Anything else you need in the meantime?
 Will Cutforth
superuser
For now, nothing more thanks
willcutforth
Fixes: 113
How did the appointment go @superuser ?
 Will Cutforth
superuser
They suspect a issue with a line from my nearest pole running to CAB
It has a repair in it. Apparently it's a well know issue, but it's a bigish cable and they seemed reluctant in the past to do much. It might get done now, eventually.
superuser
They were working on the line this week. Not sure what was done
But the issue remains
Becoming a real pain
adamwalker
Fixes: 223
Hi Superuser, sorry to see that's still an issue. Line tests show me that there's an MSO (major service outage) affecting your area at the moment which was opened on 30/12/22. The estimated completion date is 10/1/23 so we're hoping to see that sorted quickly and sorry for the disruption!
 Adam Walker
adamwalker
Fixes: 223
Hey superuser, I've just checked back on this for you and the MSO has been cleared. Everything back to normal for you now?
 Adam Walker
superuser
Well, looking at my connection log, no.
Although I have not been at my devices during a dropout, I know it is dropping.
superuser
When I checked again this morning at 5.30am the connection has been up 3 hrs 40 min
So it had been down in the middle of the night
I'll keep checking
superuser
Same again today, although it had been up a couple of days as I had been checking
willcutforth
Fixes: 113
This is the log I can see from my side, does this match up with you?
 Will Cutforth
superuser
As far as I can tell, it does
superuser
You can add 5.50am today 15th
I was online with a friend abroad
It's a bit silly all this.
