Disconnects - Help Please
TheMightyAJ
Fixes: 126
Re: Disconnects - Help Please
Not to worry, just post here in the thread once you've had a chance and one of us will pick this back up for further review Smiley
 Alex H
superuser
Draytek
 DOWNLOAD Mbps
62.58
 UPLOAD Mbps
9.42
Ping ms  21  69  69
superuser
Down again
2nd December early morning
superuser
Basically it was down when I got up at 5am
It's still down now at 7.35
Resorting to a hotspot from my phone to message here
adamwalker
Fixes: 223
Hi @superuser, sorry to see this, logs show that you've been online without any disconnections since you posted. How are things from your point of view? - Adam
 Adam Walker
superuser
Have more disconnects
Most days
superuser
It's odd because the new draytek router is syncing much better
Actual Rate 79997 Kbps 15984 Kbps
Attainable Rate 82006 Kbps 15876 Kbps
But it's like someone is messing in the CAB. Connection just drops
Usually not for too long. A few mins or perhaps 15 or so, just random.
willcutforth
Fixes: 113
Hey there @superuser I hope you're doing well this Xmas Eve.
I did a test on the line and it came up with Cross Talk and is asking for an engineer to come out to have a look at the line, when would you be free for an engineer?
 Will Cutforth
superuser
Yes, I'm free
willcutforth
Fixes: 113
So they do slots between 8-1 or 1-6. It's going to be a bit of a pain with the Xmas period but are you free from Tuesday onwards?
 Will Cutforth
superuser
I'm free
Any day or time, so long as I know
RealAleMadrid
Fixes: 68
@superuser  I noticed in an earlier post in this thread "I use an Asus DSL-AC68U" I strongly suggest you never use that device again, it has probably the worst ever VDSL2 modem chipset in it causing grief for many users. It is known to not work well with the openreach DLM system, causing reduced speeds and dropouts. As you say the Draytek is syncing at almost the full downstream rate which is good. The cause of your dropping connection is still not explained but I would stick with the Draytek router and put the Asus in a dark cupboard.😁
I am surprised that crosstalk is suggested as a possible cause by @willcutforth , that is due to interference in the lines from the cabinet and causes lower speeds which does not seem to apply to your situation, also an engineer can do nothing to change it. The engineer visit may not achieve much.☹️ Intermittent faults are always a difficult problem as it's usually working fine when someone comes to have a look.
superuser
The Asus is indeed in a dark cupboard
Thanks for the input
It's odd, as I said, that speed and sync is good if there is a fault.
I'll leave it to those who should know best.
Plus net are always very helpful and quick
willcutforth
Fixes: 113
@RealAleMadrid yeah I normally agree, I just have to follow the pesky troubleshooter in which I have fedback on anyway. It didn't ask to do any checks or anything you would normally look at for it.
 Will Cutforth
superuser
Well, I have not been contacted at this point. By openreach I mean.
Still get regular drops. Having a Zoom meeting is getting really awkward
