Disconnects - Help Please
Fixes: 246
Re: Disconnects - Help Please
@willcutforth
Many of those drops are 2-3am typical time for BTw engineering works or indeed DLM line adjustments.  Is there any evidence to support that please?
superuser
So You are suggesting daily dropouts is fine?
Because there is a pattern mostly as you say early morning
But it's not usual is it !
And who on earth is doing such work at those early hours. I don't get it.
Day after day?
Fixes: 246
Major work is done in the early hours, especially automated stuff.  Something physical has to be responsible for breaks at such regular times.  This first step is to ask the right questions.
I do believe that where, for whatever reason DLM action is profiling a line, that happens at 2am.
superuser
Over to you guys to ask the right questions then.
Mine is simple: What is with all the disconnects ?
Thank you
superuser
Just checked and my line has only been up 30 min
It's 5.30am now, so it went down just around or before 5am today 16th
adamwalker
Fixes: 223
Hi @superuser, line tests aren't showing us any obvious issues for the disconnection. If you haven't already would you be able to try connecting into the test socket for a while so we can see if the same issue happens?
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
 Adam Walker
superuser
Adam
I might be able to. I'd need to see if I can find a microfilter, not sure I have any, pretty sure I don't.
The issue might just be I live in Argyll. What goes down here in every aspect of life is just unbelievable
Fixes: 246
@adamwalker
Is there any evidence of DLM adjustments or BTw engineering works at the time of the disconnections?
superuser
I can see it's been off again just before 2am 17th
As my current up time is 4 hrs at 6am
Router up time 406 hrs
superuser
Similar again this morning
It's 5.40am now
It's been up 3hrs
Fixes: 246
The other explanation is a switching spike on some timer controlled appliance. Will your router work with router stats. See the link below.
superuser
It's running now
Switching Spike? You mean perhaps like a heating thermostat?
superuser
Because that's the only device that perhaps comes on at night, but it's never that regular.
I actually just triggered it to come on and off but no effect
superuser
I will leave it on tonight, but is this the sort of thing you want
superuser
Missed this
