Dns seems high
cjcshadowsan
Re: Dns seems high
Unfortunately the downside of using a load balancer to hand out requests vs. anycast and a massively shared cache on the backend (i'm looking at you google)...
...To make more wide-ranging changes will unfortunately have to wait until major scaling at which point a lot of things will be addressed, so please bear with us.
In the meantime, if this exact same config is deployed across the rest of the cachedns estate then performance will be much improved.
[Moderator's note by Dick (Strat):  Full quote of preceding post removed, as per Forum Rule]
And again, as an aside - i'm pretty bored of having posts moderated for merely answering questions now when other forum users don't get the same treatment. Just an observation mods.
npr
Fixes: 9
Re: Dns seems high
Quote from: Chris
Would a single cache be that much bigger?
I would have thought the vast majority of entries would be the same in all 10 caches.
Do you have any data to clarify this?
Sorry Chris but I'm not seeing anything at this end to say the new resolver is a step forward.
30FTTC06
Fixes: 4
Re: Dns seems high
Quote from: Chris
Well, there is only 1 way to find out if it will be a success i guess. I'm also adding a view from the south below, taken @22:45 ish.
Re: Dns seems high
Also from down south at 23:45, and the same four DNSes at the bottom of the chart  Cry
dave
Fixes: 4
Re: Dns seems high
Quote from: ejs
Linux, Fedora 20, the clue is in:
; <<>> DiG 9.9.4-RedHat-9.9.4-8.fc20 <<>> @212.159.6.9 www.gnu.org +tries=1
(RedHat / Fedora, fc20 = Fedora 20)
Here are some more:
http://ejs1920.users.sourceforge.net/more-dig+adflag.pcap
They aren't all 0x80, that capture was mainly me trying to spot any patterns with what causes the responses to be marked 0x20 - it seems to depend on which server (9 and 10 vs. 49 and 50) and what hostname you look up.
This should be fixed now and in titanium.
Dave Tomlinson
Plusnet Technology
30FTTC06
Fixes: 4
Re: Dns seems high
I seem to be getting problems on DNS as well now.
Nameserver          	Response Time (ms)
                    min/avg/max/stdev/retries
212.159.6.9        18.82/20.72/22.02/1.13/0
212.159.6.10        18.56/19.00/19.58/0.42/0
212.159.13.49      18.51/19.00/19.52/0.24/1
212.159.13.50      18.29/18.86/19.78/0.55/0
212.159.6.9        18.28/18.83/19.57/0.51/0
212.159.6.10        18.11/18.51/18.92/0.32/0
212.159.13.49      18.24/18.75/19.28/0.37/0
212.159.13.50      18.96/19.19/19.51/0.21/1
212.159.6.9        18.70/19.21/19.73/0.38/0
212.159.6.10        18.15/18.70/19.54/0.47/0
212.159.13.49      18.16/18.83/19.57/0.52/1
212.159.13.50      18.57/18.97/19.56/0.45/0
212.159.6.9        18.22/19.64/22.64/1.69/1
212.159.6.10        18.35/18.85/19.31/0.39/0
212.159.13.49      18.02/18.70/19.55/0.52/0
212.159.13.50      18.20/18.89/19.54/0.46/0
ejs
Aspiring Hero
Fixes: 25
Re: Dns seems high
I assume the problem in those numbers is the retries.
One current problematic hostname for the PN DNS servers seems to be radar.cedexis.com (some advertising / tracking rubbish on some website) which gets a SERVFAIL response much of the time (but not always).
There should be very little point in testing each of 212.159.6.9, 212.159.6.10, 212.159.13.49 and 212.159.13.50 - they are all effectively the same.
30FTTC06
Fixes: 4
Re: Dns seems high
Yes the timeout/retries ejs
I assume dns_bench is testing against google.com which is what i'm using. I think that timeout equates to 2000ms
results from dns top give me
Queries: 0 new, 133 total                              Sun Jan 26 17:07:24 2014
Source       Query Name                    Count      %   cum%
192.168.0.15 www.google.com                  132   99.2   99.2
192.168.0.15 30.0.168.192.in-addr.arpa         1    0.8  100.0
I've been having trouble streaming as well, I've just not managed to put my finger on it as yet, so i just threw the net wide just incase anybody else is having trouble at all.
Edit: As you say it makes no odds testing 2 of the same, however,  nothing else i'm testing is having any issue dns wise.
212.159.6.9        19.30/19.59/19.76/0.19/1
212.159.6.10        18.40/18.89/19.46/0.37/0
208.67.222.222      17.90/18.79/19.55/0.64/0
208.67.222.220      18.20/18.45/18.67/0.15/0
208.67.222.123      17.97/18.39/19.02/0.36/0
208.67.220.123      18.20/18.70/19.29/0.40/0
8.8.8.8            23.39/25.24/29.50/2.18/0
8.8.4.4            24.27/24.66/24.99/0.31/0
4.2.2.1            17.94/18.32/19.05/0.41/0
4.2.2.6            18.13/18.39/18.88/0.27/0
192.168.0.254      19.54/19.70/19.93/0.14/0
192.168.0.15        0.61/0.62/0.67/0.02/0
208.67.222.222      17.90/18.20/18.67/0.28/0
208.67.222.220      17.94/18.23/18.38/0.16/0
208.67.222.123      18.15/18.40/18.73/0.22/0
208.67.220.123      18.02/18.24/18.49/0.18/0
8.8.8.8            23.57/24.37/26.36/1.03/0
8.8.4.4            23.78/24.35/25.15/0.54/0
4.2.2.1            17.88/18.16/18.66/0.29/0
4.2.2.6            18.02/18.32/18.50/0.16/0
192.168.0.254      19.26/19.73/20.21/0.35/0
192.168.0.15        0.60/0.61/0.61/0.00/0
212.159.6.9        18.55/19.13/19.88/0.39/1
212.159.6.10        18.35/19.08/19.80/0.58/0
VileReynard
Fixes: 20
Re: Dns seems high
My "Sam knows" stats say this:-
Things looking bad (again)...
30FTTC06
Fixes: 4
Re: Dns seems high
That makes more sense, My ps3 is running on plusnet dns which is what I use to stream iplayer on.
I'd nearly forgot all about my whitebox  Grin
30FTTC06
Fixes: 4
Re: Dns seems high
Well i'm still seeing issues with "plusnet" dns after things have settled down.
 Nameserver              Response Time (ms)                        min/avg/max/stdev/retries
212.159.6.9            18.00/18.42/18.73/0.27/1
212.159.6.10            17.67/18.42/18.87/0.42/0
208.67.222.222          18.00/18.24/18.60/0.20/0
208.67.222.220          18.03/18.19/18.40/0.17/0
208.67.222.123          17.91/18.12/18.34/0.15/0
208.67.220.123          17.91/18.10/18.36/0.19/0
8.8.8.8                23.73/24.04/24.27/0.18/0
8.8.4.4                23.69/24.09/24.42/0.26/0
4.2.2.1                17.74/18.07/18.38/0.23/0
4.2.2.6                17.73/18.01/18.38/0.25/0
192.168.0.254          19.26/19.57/19.80/0.18/0
192.168.0.15            0.60/0.63/0.70/0.04/0
Kelly
Fixes: 9
Re: Dns seems high
Our graphing looks more wobbly since Thursday afternoon.  I've flagged into Ops.
Kelly Dorset
Ex-Broadband Service Manager
Kelly
Fixes: 9
Re: Dns seems high
One of the servers in PTN/PTW was misbehaving. It's been given a swift talking to and is now back in service.
Kelly Dorset
30FTTC06
Fixes: 4
Re: Dns seems high
Many thanks for taking the time to reply Kelly, Much appreciated.
30FTTC06
Fixes: 4
Re: Dns seems high
Here we go again.... no packet loss yet I'm getting dns failing.
--- bbc.co.uk ping statistics ---101 packets transmitted, 101 received, 0% packet loss, time 100152ms
rtt min/avg/max/mdev = 17.424/18.476/23.675/0.980 ms
212.159.6.9             17.90/18.64/19.06/0.44/1
212.159.6.10            18.21/18.88/19.39/0.43/0
208.67.222.222          18.25/18.49/18.61/0.14/0
208.67.222.220          17.89/18.15/18.35/0.18/0
208.67.222.123          17.68/18.36/19.30/0.53/0
208.67.220.123          18.48/18.70/18.83/0.13/0
8.8.8.8                 23.50/24.12/24.81/0.50/0
8.8.4.4                 23.62/24.29/25.30/0.57/0
4.2.2.1                 18.14/19.16/20.44/0.98/0
4.2.2.6                 17.74/18.20/18.62/0.30/0
Edit:  A bit more info added
590 packets transmitted, 590 received, 0% packet loss, time 589238ms
rtt min/avg/max/mdev = 16.983/18.052/23.176/0.676 ms
(0.0.0.0)                                      Mon Jan 27 20:54:55 2014
Keys:  Help  Display mode  Restart statistics  Order of fields  quit
                                      Packets              Pings
Host                                Loss%  Snt  Last  Avg  Best  Wrst StDev
1. 192.168.0.254                    0.0%  230  24.8  40.1  1.6 100.5  25.2
2. lo0-central10.pcl-ag06.plus.net  0.0%  230  16.7  26.9  16.4 291.4  31.8
3. link-a-central10.pcl-gw01.plus.n  0.0%  229  17.2  17.6  16.5  35.2  1.3
4. xe-10-3-0.pcl-cr01.plus.net      0.0%  229  36.6  18.8  16.1  55.7  5.0
5. po2.pcl-gw01.plus.net            0.0%  229  17.1  17.7  16.3  83.9  4.6
6. vl63.pcl-lb01.plus.net            0.0%  229  18.2  18.3  16.8  31.0  1.2
7. cdns01.plus.net                  0.0%  229  17.1  18.3  16.7  25.2  1.1
(0.0.0.0)                                      Mon Jan 27 20:55:23 2014
                                      Packets              Pings
1. 192.168.0.254                    0.0%  394  18.7  51.4  0.7 100.3  32.3
2. lo0-central10.pcl-ag06.plus.net  0.0%  394  21.3  27.3  16.4 504.9  38.5
3. link-a-central10.pcl-gw01.plus.n  0.0%  394  17.3  17.6  16.1  34.8  1.7
4. xe-10-3-0.pcl-cr01.plus.net      0.0%  394  18.4  18.0  16.1  50.1  3.7
5. ae1.ptw-cr01.plus.net            0.0%  394  17.8  18.2  16.2  47.3  3.5
6. te9-4.ptn-gw01.plus.net          0.0%  394  20.4  17.6  16.5  32.2  1.1
7. gi5-1.peh-cr02.plus.net          0.0%  394  24.7  26.5  23.6  92.6  5.4
8. po5.peh-cr01.plus.net            0.0%  394  30.5  26.4  23.9  58.0  2.7
9. vlan2658.peh-elb02.plus.net      0.0%  393  25.9  27.6  24.2  86.7  4.3
10. portal.plus.net                  0.0%  393  26.1  28.1  24.5  79.2  6.1
No sign of packet loss in that lot.
