Dns seems high
- Dns seems high
Re: Dns seems high
28-01-2014 9:24 AM
Ex-Broadband Service Manager
Re: Dns seems high
28-01-2014 10:15 AM
212.159.6.9,212.159.6.10 which are set static per device, open dns is fine, all the tests above are using dns_bench via port 53 using google.com.for testing. Apart from the pings of course
Re: Dns seems high
28-01-2014 10:40 AM
Today the loss i'm seeing which is only over UDP and is now showing up over multiple dns servers, i've tested on mutiple devices direct from the router. ie the problem seems to be getting worse.
Any thoughts ?
Nameserver Response Time (ms)
min/avg/max/stdev/retries
212.159.6.9 17.51/17.91/18.41/0.32/1
212.159.6.10 17.17/17.86/18.87/0.60/0
208.67.222.222 17.22/17.53/17.82/0.22/0
208.67.222.220 17.44/17.79/18.81/0.51/0
208.67.222.123 17.27/17.50/17.68/0.15/0
208.67.220.123 17.09/17.38/17.62/0.18/0
8.8.8.8 22.94/24.08/26.34/0.69/1
8.8.4.4 22.94/23.60/24.89/0.68/0
4.2.2.1 17.17/17.53/17.75/0.22/1
4.2.2.6 17.05/17.31/17.43/0.16/0
4.2.2.2 17.11/17.35/17.52/0.14/0
4.2.2.5 17.23/17.46/17.70/0.15/0
4.2.2.5 17.00/17.25/17.66/0.22/0
4.2.2.3 16.97/17.35/17.64/0.30/0
This is the first time i've seen an issue with any other dns, some kind of spike happening lasting seconds. Let me know if you want me to hop gateway, but i would rather leave it as is for the moment.
Re: Dns seems high
28-01-2014 5:47 PM
See the waiting times on the followiing.
Re: Dns seems high
28-01-2014 5:51 PM
Re: Dns seems high
28-01-2014 5:53 PM
(0.0.0.0) Tue Jan 28 17:55:41 2014
Keys: Help Display mode Restart statistics Order of fields quit
Packets Pings
Host Loss% Snt Last Avg Best Wrst StDev
1. 192.168.0.254 0.0% 35 94.7 42.5 1.9 99.5 25.5
2. lo0-central10.pcl-ag06.plus.net 0.0% 35 16.8 35.1 16.6 282.0 56.0
3. link-a-central10.pcl-gw01.plus.n 0.0% 35 16.6 17.0 16.4 19.6 0.4
4. xe-10-3-0.pcl-cr01.plus.net 0.0% 35 18.8 19.0 15.8 50.9 7.7
5. po2.pcl-gw01.plus.net 0.0% 35 16.5 16.7 16.1 17.5 0.0
6. gi5-8.ptp-cr01.plus.net 0.0% 35 24.4 24.2 23.7 25.0 0.0
7. vlan2658.ptp-elb02.plus.net 0.0% 34 25.3 25.5 24.5 29.9 0.8
8. portal.plus.net 0.0% 34 25.0 25.2 24.2 27.1 0.4
Re: Dns seems high
28-01-2014 5:59 PM
Re: Dns seems high
28-01-2014 6:12 PM
Re: Dns seems high
28-01-2014 8:41 PM
ie the red through the ip address represents failed lookups.
Re: Dns seems high
28-01-2014 9:15 PM
212.159.6.9 18.16/20.22/22.68/1.72/1
212.159.6.10 19.88/21.19/22.92/1.14/0
212.159.13.49 18.64/19.10/19.58/0.34/0
212.159.13.50 19.65/20.03/20.61/0.24/1
Nigel, I'm seeing loss of upto 2000ms represented by 1 retries on the above test which I tested at the time of this post, i've also posted a little .jpg test below as well.
However! as you can see below i was getting failures across other dns-servers with the same test as above. But i can't replicate failures that i was getting from the tests below tonight.
Re: Dns seems high
28-01-2014 9:49 PM
Re: Dns seems high
28-01-2014 10:06 PM
I was about to blame the load unbalancer, but 212.159.6.129 managed to catch up with the timeouts towards the end of the testing, to finished tied with 212.159.6.9 in a race to be the worst DNS server.
Out of 406 queries to each:
212.159.6.9: 19 timeouts
212.159.6.129: 19 timeouts
212.159.6.130: 0 timeouts
212.159.6.131: 11 timeouts
212.159.6.132: 0 timeouts
Re: Dns seems high
29-01-2014 9:54 AM
212.159.6.9 17.21/17.73/18.04/0.31/0
212.159.6.10 17.67/17.77/17.86/0.07/0
212.159.13.49 17.23/17.68/18.30/0.24/1
212.159.13.50 17.58/17.79/18.07/0.19/1
208.67.222.222 17.37/17.67/17.88/0.20/0
208.67.222.220 17.62/17.72/17.85/0.08/0
208.67.222.123 17.47/17.94/18.58/0.38/0
208.67.220.123 17.40/17.68/17.91/0.22/0
8.8.8.8 23.09/23.60/24.07/0.40/0
8.8.4.4 22.87/23.43/23.97/0.39/0
4.2.2.1 17.08/17.51/17.89/0.28/0
4.2.2.6 17.40/17.69/18.02/0.22/0
4.2.2.2 17.13/17.54/17.77/0.22/0
4.2.2.5 16.99/17.49/17.86/0.28/0
4.2.2.5 17.36/17.57/17.79/0.16/0
4.2.2.3 17.22/17.51/17.90/0.27/0
192.168.0.254 18.51/19.03/19.53/0.41/0
192.168.0.15 0.92/0.95/0.97/0.02/0
--- bbc.co.uk ping statistics ---
116 packets transmitted, 116 received, 0% packet loss, time 123252ms
rtt min/avg/max/mdev = 16.225/16.810/17.348/0.248 ms
lo0-central10.ptn-ag03.plus.net
212.159.6.9 17.46/18.13/18.78/0.45/0
212.159.6.10 17.73/18.14/18.53/0.26/0
212.159.13.49 17.94/18.23/18.55/0.24/0
212.159.13.50 17.77/18.10/18.83/0.37/0
208.67.222.222 17.57/17.94/18.37/0.26/0
208.67.222.220 17.50/17.79/18.16/0.23/0
208.67.222.123 17.44/18.02/18.58/0.41/0
208.67.220.123 17.52/18.08/18.38/0.29/0
8.8.8.8 23.18/23.52/23.95/0.29/0
8.8.4.4 22.98/23.52/24.65/0.59/0
4.2.2.1 17.76/18.04/18.38/0.21/0
4.2.2.6 17.25/17.48/17.67/0.18/0
4.2.2.2 17.24/17.43/17.63/0.17/0
4.2.2.5 17.12/17.54/17.83/0.25/0
4.2.2.5 17.01/17.57/17.89/0.32/0
4.2.2.3 17.60/18.01/18.24/0.25/0
192.168.0.254 18.88/19.24/19.55/0.21/0
192.168.0.15 0.95/0.98/1.01/0.03/0
116 packets transmitted, 116 received, 0% packet loss, time 115167ms
rtt min/avg/max/mdev = 16.429/16.823/17.404/0.263 ms
Which gateway was you on npr ?
I'll see how this pans out again later Kelly, but for now things have improved on this gateway.
Re: Dns seems high
29-01-2014 10:12 AM
>11110_110 Are you still seeing the website delay
Re: Dns seems high
29-01-2014 11:39 AM
Just tested again from pcl and then ptw.
From PCL
From PTW
So PTW is indeed improved.
Hope there's still some more dns upgrades to come, it needs them.
