Fibre speed estimate
- Fibre speed estimate
09-06-2014 9:32 AM
I probably missed it but is there somewhere that I can get an estimate of speed if I switch to fibre?
I can find the broadband but no mention of fibre speed. Thanks in advance.
Message 1 of 6
(1,027 Views)
5 REPLIES 5
Re: Fibre speed estimate
09-06-2014 9:45 AM
Hi doris barloff,
You can visit https://www.dslchecker.bt.com/ and type in your telephone number and it'll tell you if Fibre is available, if it is, it'll give you a speed estimate too.
Message 2 of 6
(639 Views)
09-06-2014 8:34 PM
Hi doris barloff,
I would take that reply with a pinch of salt. My speed on dsl checker is between 60 downstream high, 43 downstream low, ------ 17 upstream high, 10 up stream low.
Plusnet estimate 43 down,-------actual speed is 30Mb down and 7Mb up.
I raised a fault on this with Pn, as on change over to FTTC for 10 days my speed was above 40 Mb, However I am now told they do not regard this as a fault unless it drops below 23Mb.
I am on the full 80/20 package.
I hope this helps in your decision.
regards smiler1
( READ MY THREAD "FTTC SLOWING DOWN BELOW ESTIMATE")
regards smiler1
Message 3 of 6
(639 Views)
09-06-2014 9:10 PM
Message 4 of 6
(639 Views)
09-06-2014 10:27 PM
they said my estimate was 29mb I get 21mb put far happy has I need a deal for 18months so only £3.00 more then I was paying for normal broadband
conrad
conrad
Message 5 of 6
(639 Views)
09-06-2014 10:55 PM
Yeah I wouldn't take the speed estimates provided from BT as gospel , when i joined plusnet back in March my estimate was 67Mb when connected i synced at 65Mb ( currently not the case bu that's a different matter) about three weeks ago BT dropped it to 29Mb with no warning or explanation as to why they did that despite asking plusnet if they can get BT to say why i still have no clue or answer as to why they dropped it by more than half in almost three months of me joining so be aware what you see now may not be that way weeks or a couple of months from now.
Message 6 of 6
(639 Views)
