what is the correct term for this.....
outcast
Aspiring Champion
Fixes: 19
Re: what is the correct term for this.....
@shutter
As it appears that you could likely get a replacement knob in the right size and with the finger dimple,
isn't the easiest solution just to swap the knob for a new one, as it is likely just a grub screw attachment ?
You could keep the original knob somewhere safe, in case you ever wanted to revert back to the original design.
shutter
Fixes: 67
@outcast  Yup !  could do that .. but there are two big knobs on this receiver, that match the whole colour scheme  and I don`t think the expense of replacing them both is worth it.
just adding a stick on "dimple" would be no problem. ( could even add one to each to "match" the pair ! )
outcast
Aspiring Champion
Fixes: 19
Unfortunately I can't see the photo, I guess I'll just have to tag @James_B to get the picture unblocked Crazy2
What an effing waste of everybody's time, this situation is hopeless.
outcast
Aspiring Champion
Fixes: 19
@shutter wrote:
... I don`t think the expense of replacing them both is worth it.
Is £1.72 too expensive ?
Screenshot 2025-09-06 at 09-51-36 Alps 863002 Rotary Knob Finger Grooves Easy Grip Control.png
There is the risk though that it might take so long for @James_B  to unblock this image, that it might have gone obsolete !
shutter
Fixes: 67
@outcast   wonder if it is something in your settings for your profile, as it appears in my posting.
outcast
Aspiring Champion
Fixes: 19
@shutter@James_B  -  I posted my last image more than an hour ago, but this is what I currently see -
shutter
Fixes: 67
@outcast  Yes i see the same trianlge symbol on your postings but not on mine.
outcast
Aspiring Champion
Fixes: 19
Yes, that is how it now works.
I can see what I posted, but nobody else can until a moderator 'approves' my images.
Similarly you can see what you posted, but nobody else can until approved.
Hopefully on Monday when @James_B  sees all his tagged notifications, he will roll back the forum to working as it used to ?.
shutter
Fixes: 67
@outcast  OK... as the saying goes.......  " Ah Well! "Wink
meantime... check out this link to a pic of same receiver.....
https://www.radiomuseum.org/r/eddystone_s940s_94.html
RobPN
Fixes: 13
@shutter wrote:
... so will just have to try and figure out a way of manufacturing one from some old plastic and a 10mm drill, or large countersink bit ...
Probably better to use a router cutter, e.g. like this one.
Other sizes / cheaper brands are available.
shutter
Fixes: 67
You buy it..Shocked  . and send it to me f.o.c....   Shocked  Shocked..
and I`ll give it a go.  Smiley
RobPN
Fixes: 13
Ah yes, the wallet ...
As per request, done.
I've just nipped down to the Post Office and sent you a couple of different sizes ...
Let me know if you need anything else.  Wink
shutter
Fixes: 67
Can you give me the tracking number and expected date of delivery please. Huh
RobPN
Fixes: 13
I didn't pay the postage, just dropped it in the mailbox.
I thought you could at least afford the fee to receive it.
https://help.royalmail.com/personal/s/article/Help-with-paying-a-fee-to-receive-my-item
Expect it when you see it.
shutter
Fixes: 67
So.. not really then....  just trolling ,.... as usual Cool
