VOIP on three mobile home broadband
mystreet1
Seasoned Pro
Fixes: 7
Hi all,
Has anyone got VOIP working successfully on three mobile home broadband? Tried today and it appears that all setting are disabled on the router (rebadged HUAWEI B535). All it states is CLNAT is in use, this function has been disabled. Think that it may be due to three using IP6.
TIA
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
3 REPLIES 3
Fixes: 585
Re: VOIP on three mobile home broadband
@mystreet1 If Three are using CGNAT then you won't be able to implement any port forwarding on the router. So configuring your voip device to use STUn and then port forwarding on the router won't work.
You should/might be able to get voip working by configuring your voip device to use 'NAT keep alive'
markhawkin
Champion
Fixes: 22
It is likely that (leaving aside any network constraints) that the "3" custom firmware disbles this feature.
I would try a VoIP client on a phone connected to the router's WiFi.
If that works then there is hope of getting a router working with VoIP.
Then investigate alternative firmware for the router.
There is (or was) a "3" APN that wasn't CGNAT.
Fixes: 1,495
Moderators Note
This topic has been moved from Everything Else to Tech Help
