what is the correct term for this.....
shutter
Fixes: 67
Does anyone know the correct term for this
I know there is a correct name for the "hole" offset on a tuning knob on some radios, to facilitate faster rotation /  tuning,  by using one finger and rotating the knob at a faster rate than using the outer edge being gripped by the fingers.
I also know it is possible to buy a "stick-on" version, which I want to buy for a radio I have, but need to know the correct term to search for a supplier.
Thank you
36 REPLIES 36
Fixes: 479
Re: what is the correct term for this.....
@shutter
In the RS catalogue there’s a horrendously priced one under plain old potentiometer knobs. See Elma 39mm black pot knob K1-DM-B60.
outcast
Aspiring Champion
Fixes: 19
I would love to try and help my old friend @shutter , but all I can see is one of @James_B 's Fking yellow triangles ! Knuppel
Fixes: 479
@outcast
Try again. It’s late at night and I failed to release it.
outcast
Aspiring Champion
Fixes: 19
@Baldrick1
still can't see it - although I don't really care (I was just making a point !),
I got the gist from Googling your reference to the Elma K1-DM-B60
@shutter
try searching for "jog control knob"
also "jog dial", "jog wheel", "shuttle dial", or "shuttle wheel"
or "finger control knob"
outcast
Aspiring Champion
Fixes: 19
@shutter
so the above terms give you something like this -
or "finger crank control knob" appear to have a fancy spinning insert -
Oh for [-Censored-] @James_B 's [-Censored-]  image censorship is interfering with editing posts with yet to be approved images, with the cursor not being in the right place, so any editing isn't happening where the cursor is showing.
@James_B  just roll back this ridiculous censorship it is making this forum unusable !!!
Moderators Note:  Avoidance of swear filter removed
shutter
Fixes: 67
Hi Guys.
Thanks for the input....but I do not want to replace the knob on the receiver... I just want the correct term for the "hole".. so I can purchase a "stick - on " version..
Checking out "kranker" found the term "dimple"  so maybe that will be the route to follow.
Thanks again.
outcast
Aspiring Champion
Fixes: 19
@shutter  how big is your knob ?  Shocked
so I can narrow down any searches for stick-on dimples to your required diameter ?
outcast
Aspiring Champion
Fixes: 19
@shutter
I think you are referring to the HAM radio "elecraft finger dimple" - which appears to have gone out of production in 2016.
You might want to search for alternatives to "elecraft finger dimple", unless I find one first.
https://www.eham.net/reviews/view-product/4061
outcast
Aspiring Champion
Fixes: 19
@shutter
I asked Grok, which came back with this -
Screenshot 2025-09-06 at 00-29-19 Self-Adhesive Knob Dimple Solutions - Grok.png
They appear to have been here in the UK, but currently out of stock -
https://www.hamradiostore.co.uk/finger-dimple-fd-gry-fingerdimple-packet-of-2-grey
There are a few other outlets that list "FD-GRY finger dimple", but so far they are all out of stock.
outcast
Aspiring Champion
Fixes: 19
I give up !
I tried getting Grok to do an exhaustive worldwide search, only to conclude -
Screenshot 2025-09-06 at 00-47-33 Self-Adhesive Knob Dimple Solutions - Grok.png
@shutter @outcast
I have released the images for you
Maybe for now try using attachments rather than posting images.
shutter
Fixes: 67
@outcast  Thank you very much for your time spent searching and researching for the answer.. and for the link to Waters & Stanton site... As it seems they have been out of stock for some time, probably looking for a dead dodo now.. so will just have to try and figure out a way of manufacturing one from some old plastic and a 10mm drill, or large countersink bit ...
Much appreciate the time an effort you have put in
cheers
Fixes: 479
@shutter
Unless you know someone with a 3d printer?
shutter
Fixes: 67
@Baldrick1  a good suggestion..Thumbs_Up...... but .... unfortunately, I don`t !. Cry
