what is the correct term for this.....
FIXED- Subscribe to RSS Feed
- Re: what is the correct term for this.....
06-09-2025 8:57 AM
As it appears that you could likely get a replacement knob in the right size and with the finger dimple,
isn't the easiest solution just to swap the knob for a new one, as it is likely just a grub screw attachment ?
You could keep the original knob somewhere safe, in case you ever wanted to revert back to the original design.
06-09-2025 9:25 AM
@outcast Yup ! could do that .. but there are two big knobs on this receiver, that match the whole colour scheme and I don`t think the expense of replacing them both is worth it.
just adding a stick on "dimple" would be no problem. ( could even add one to each to "match" the pair ! )
06-09-2025 9:38 AM
Unfortunately I can't see the photo, I guess I'll just have to tag @James_B to get the picture unblocked ![]()
What an effing waste of everybody's time, this situation is hopeless.
06-09-2025 9:56 AM
06-09-2025 10:53 AM
@outcast wonder if it is something in your settings for your profile, as it appears in my posting.
06-09-2025 10:59 AM
06-09-2025 11:20 AM
@outcast Yes i see the same trianlge symbol on your postings but not on mine.
06-09-2025 11:35 AM
Yes, that is how it now works.
I can see what I posted, but nobody else can until a moderator 'approves' my images.
Similarly you can see what you posted, but nobody else can until approved.
Hopefully on Monday when @James_B sees all his tagged notifications, he will roll back the forum to working as it used to ?.
06-09-2025 12:20 PM - edited 06-09-2025 12:22 PM
@outcast OK... as the saying goes....... " Ah Well! "![]()
meantime... check out this link to a pic of same receiver.....
https://www.radiomuseum.org/r/eddystone_s940s_94.html
07-09-2025 9:07 PM
@shutter wrote:
... so will just have to try and figure out a way of manufacturing one from some old plastic and a 10mm drill, or large countersink bit ...
Probably better to use a router cutter, e.g. like this one.
Other sizes / cheaper brands are available.
07-09-2025 9:46 PM
You buy it..
. and send it to me f.o.c....
and I`ll give it a go. ![]()
08-09-2025 11:21 AM - edited 08-09-2025 11:30 AM
Ah yes, the wallet ...
As per request, done.
I've just nipped down to the Post Office and sent you a couple of different sizes ...
Let me know if you need anything else. ![]()
08-09-2025 12:20 PM
Can you give me the tracking number and expected date of delivery please. ![]()
08-09-2025 1:20 PM
I didn't pay the postage, just dropped it in the mailbox.
I thought you could at least afford the fee to receive it.
https://help.royalmail.com/personal/s/article/Help-with-paying-a-fee-to-receive-my-item
Expect it when you see it.
08-09-2025 1:54 PM
So.. not really then.... just trolling ,.... as usual ![]()
