Wiping/formatting/deleting a DVD+rw
FIXED- Subscribe to RSS Feed
- Re: Wiping/formatting/deleting a DVD+rw
29-04-2020 1:11 PM
Using Linux Mint 19.1 ( updated ) .
Have got some old versions of Mint on DVD+rw discs, that I would like to be able to reuse.. but I cannot format them... delete the contents, etc...
Any advice Please ?
Fixed! Go to the fix.
29-04-2020 1:40 PM
29-04-2020 1:50 PM
I don't think you'll be able to to be honest, as I am sure the session needs to be closed to be bootable and once it's closed all you have a place mat.
29-04-2020 1:52 PM
29-04-2020 1:57 PM
@dvorak That`s what I thought the RW stood for.....ReWritable... ! .
29-04-2020 2:08 PM - edited 29-04-2020 2:10 PM
@dvorak wrote:
Have you installed dvd+rw-tools ?
No... did not know I had to .... I installed XFBurn. and burned the .iso with that... . but it does not "undo" a burn ... not even when you select "blank"
so... where would I get dvd+rw tools from.... ? ? ?
29-04-2020 2:18 PM
29-04-2020 3:22 PM
Yes, it should be and is, provided that the session has not be finalised on the disk.
29-04-2020 3:28 PM
29-04-2020 3:50 PM
O.K... Being a bit "dim" now...... but.... I have installed , from package manager,... dvd+rw tools...
I have re-booted the laptop... but I cannot find where dvd+rw tools is hiding...
Not listed on the Menu.... and using the "search" box at the bottom of the menu, it reports, No files found .
29-04-2020 3:58 PM
dvd+rw-format -force /dev/sr0
29-04-2020 4:36 PM
29-04-2020 4:37 PM
29-04-2020 4:55 PM
They don`t have a forum like this ! ! !.
.. so.... I shall probably be "lurking" around on here,.....
What they do have, is EXCELLENT email customer service...
29-04-2020 9:37 PM
A rough equivalent of Nero on Windows is k3b on Linux if you install this it will drag in a lot of libraries etc for the KDE environment (that won't get used in Mint) - but its a great GUI program for CD's & DVD's.
You install it using the package manager as per usual, but more details can be found at https://userbase.kde.org/K3b
