Wiping/formatting/deleting a DVD+rw
shutter
Fixes: 65
Using Linux Mint 19.1 ( updated ) .
Have got some old versions of Mint on DVD+rw discs, that I would like to be able to reuse.. but I cannot format them... delete the contents, etc...
Any advice Please ?
15 REPLIES 15
Fixes: 1,483
Re: Wiping/formatting/deleting a DVD+rw
Have you installed dvd+rw-tools ?
Mook
Seasoned Champion
Fixes: 9
I don't think you'll be able to to be honest, as I am sure the session needs to be closed to be bootable and once it's closed all you have a place mat.
Fixes: 1,483
shold be able to on an rw?
shutter
Fixes: 65
@dvorak That`s what I thought the RW stood for.....ReWritable... ! .
shutter
Fixes: 65
No... did not know I had to ....  I installed XFBurn.  and burned the .iso with that... . but it does not "undo" a burn ... not even when you select "blank"
so... where would I get dvd+rw tools from....  ? ? ?
Fixes: 1,483
should be included in your package manager.
Mook
Seasoned Champion
Fixes: 9
Yes, it should be and is, provided that the session has not be finalised on the disk.
Fixes: 1,483
you don't finalize sessions on +RW
shutter
Fixes: 65
O.K... Being a bit "dim" now...... but.... I have installed , from package manager,... dvd+rw tools...
I have re-booted the laptop... but I cannot find where dvd+rw tools is hiding...
Not listed on the Menu.... and using the "search" box at the bottom of the menu, it reports, No files found .
Fixes: 1,483
time to open your terminal and try something like:
dvd+rw-format -force /dev/sr0
shutter
Fixes: 65
@dvorak  Yeehah !
Thanks very much.....  Wink
Fixes: 1,483
No worries, hope your new ISP forums will be just as helpful Wink Tongue
shutter
Fixes: 65
They don`t have a forum like this ! ! !.Cry
.. so.... I shall probably be "lurking" around on here,..... Shocked    Cheesy
What they do have, is EXCELLENT email customer service...  Smiley
VileReynard
Fixes: 20
A rough equivalent of Nero on Windows is k3b on Linux if you install this it will drag in a lot of libraries etc for the KDE environment (that won't get used in Mint) - but its a great GUI program for CD's & DVD's.
You install it using the package manager as per usual, but more details can be found at https://userbase.kde.org/K3b
