Sizing photos for the web
Leapy
Seasoned Champion
My photos are jpegs and around 5MB each.
If I was to put them on the web, for say Gumtree, or eBay or Recycle,  I understand I can make them smaller, with minimal effect on the viewing quality.
Is there a simple and free way to do this and can it be done in a batch?
36 REPLIES 36
Re: Sizing photos for the web
Assuming you're on Windows then:
http://www.irfanview.com/
It's free and does batch mode as well.
chenks76
All Star
Fixes: 12
or http://birme.net/
no need to install anything.
all browser based.
shutter
Fixes: 65
@Leapy  @Anonymous The BEST image resizer is    FASTIMAGERESIZER    its free...
http://adionsoft.net/fastimageresize/
Will reduce a 5mb pic to about 800 kb without loss of detail or colouring... and...you can use the options to have the pic put in a separate SUB FOLDER in the original folder... so ... you still have the orginal size in it`s original location, and you have the resized ( smaller file version  ) in the sub folder of the orginal location...
AND... you don`t have to "open it".... just drag and drop the pics onto the desktop icon, and within a few seconds, they will be re-filed, and renumbered.... e.g... 001 880x400.jpg   so they are easily identified.
MAGIC ! ..Smiley
robski1
Fixes: 7
I have been using Image Resizer for Windows and it works very well using the right click menu in windows.
It will do batches and you can keep the originals or delete them if you wish.
You can get it here: http://www.bricelam.net/ImageResizer/
@shutter wrote:
MAGIC ! ..Smiley
There is no such thing as magic @shutter, you should know that, it is all but an illusion. Wink
shutter
Fixes: 65
@Anonymous  Ah yes, but..... have you used FastImageResizer  ?   then you will understand that it IS Magic ! ! ..
billnotben
For ebay and the like I prefer photoshop cs so I can cut and resize at the same time as well as making any necessary contrast/brightness adjustments.
Early versions can be downloaded for free.
chenks76
All Star
Fixes: 12
i'm sceptical about that claim
shutter
Fixes: 65
@billnotben As @Anonymous  says.... Irfanview.... much simpler program... and you don`t have to "load" each image from the same folder... once you have done the necessary quick crop and saved it.. you move on to the next on in the same folder...  Irfanview, is the second most magic prog going.. !.. for quick viewing and editing a days pics ( or even a month`s, if you are that busy ! ! )...
Mav
Fixes: 515
Perceivable loss, maybe?
I use IrfanView as I like the ease of use and the control I can have over the results. I haven't used FastImageResizer so perhaps that offers similar control?
Forum Moderator and Customer
Linux command line. Install free and opensource imagemagick then...
That'll resize all jpg images in a folder to 200px width and save them as png. If you want large images, just adjust the size argument.
Converseen is a cross platform application (Linux / BSD and Windows) that uses imagemagick on the backend for batch conversion.
Since it's using imagemagick, its using software that is still updated. One of the applications listed in this thread was last updated in 2009.
VileReynard
Fixes: 20
You can't discard information without some loss of quality.
shutter
Fixes: 65
@Mav   Original pic.... as seen by over 9 ,750 viewers on Flickr...
https://www.flickr.com/photos/32369450@N02/33996724474/
Cropped from the original pic at 2.12mb
and here is the resized version, with no further cropping... or colour adjusting.. courtesy of FastImageResizer.
Resized by FastImageResizer
now sized at 180kb
notice any difference between the two pics ?  colour or definition?
shutter
Fixes: 65
@VileReynard
Can you see any  loss of quality  ? ? ? ? ?
