Adapter for Macbook
southken
Adapter for Macbook
Hi All,  I'm thinking about getting a MacBook, it has a thunderbolt port so I will need an adapter to be able to use my printer, camera, etc.  There seems to be so many and all different prices.  Could anyone recommend one or confirm the type that I need?  Thanks.
2 REPLIES 2
VileReynard
Fixes: 20
Re: Adapter for Macbook
Why get a Macbook then - any other device would come with industry standard connectors.
@southken - Search online for Thunderbolt Dock as this is probably what you want if you are looking to connect various devices. But some of these aren't cheap so I hope your pockets are quite deep.
Look here to see an example of what I mean.
