Set up a guest network
mlbullen
I have a new Sagecom CS 50001 router from Plusnet. Can I set up a guest network? If so how?
8 REPLIES 8
Fixes: 586
Re: Set up a guest network
I don't recognise that model CS 50001 , AFAIK PlusNet have only supplied the Hub One and the 2704N from SagemCom
see here https://www.plus.net/help/broadband/router-setup-guides/
Which one do you have ?
TBH though I don't recall either of them being able to support guest networks
TonyMC
Hi Not sure, have asked around, why note post a question on the forum, you'll be surprised how many people will offer a possible solution!
mlbullen
Thanks for responding so quickly - its the 2704N.....
TonyMC
Hi yes, I figured as much the 2704N, I have been asking around and we feel that it won't support a guest network but as I said previously, ask on the forum, it might be possible, just never heard it happen with that particular router.
Chris
Legend
Fixes: 169
As you've already asked on the forum (ie here!) there's no need to start a new thread about this.
The 2704 does not support guest networks, sorry about that.
mlbullen
Thanks Chris.
7up
Fixes: 20
Erm... You did read post 1 right? - And what was being asked?! Do I be right if i said you worked in the call centre? - They tend to misunderstand things / give wrong advice..
@mlbullen If you have an old PC knocking around somewhere you could always find a PCI wifi card based on the ralink 2500 chipset and put it into access point mode. Then you just need to dis/enable the network card as and when you have guests. Alternatively there are usb APs out there but i've no experience of those so can't say too much.
paul_blitz
Fixes: 4
Most "mainstream" wifi routers let you set up a single WiFi network.
Yes, it IS possible to re-flash the software with other software (eg DD-WRT) that might support multiple WiFi networks, but that is possibly rather over-complex , and un supported.
Whilst you could just by a second "WiFi Access Point" (or use a cheap wifi router as one) there is still the security issue that those users are "still on your network", and could potentially access your PCs etc.
I guess it depends on why you want that guest network, and what security you need.
