My Perl cgi perl scrips have stopped working and get: http://ccgi.dougrice.plus.com/cgi-bin/wiki.pl
dougrice
http://ccgi.dougrice.plus.com/cgi-bin/wiki.pl and my other perl scripts gets
The requested URL was rejected. If you think this is an error, please contact the webmaster.
Your support ID is: 18036279169211782779
If I use Private Browsing, it renders the page, but I cannot get the Wiki into Update mode!
If I delete all cookies it works first time, but Edit mode needs cookies.
These scripts have worked for years.
I deleted the older logs. I have loads of spare space.
As webmaster where do I use the support ID?
It is the same on different computers and networks.
This started about a moth ago, and getting worse.
Any Ideas?
regards, Doug
21 REPLIES 21
dougrice
Re: My Perl cgi perl scrips have stopped working and get: http://ccgi.dougrice.plus.com/cgi-bin/wiki
A colleague said it might be to do with cookies. Does the CCGI server like cookies with & in them.
I stripped own another perl script to make it as simple as possible. It prints out the environment.
I have a wireshark capture. First one is not working, seconds one is working
GET /cgi-bin/tt.pl HTTP/1.1
Accept: text/html, application/xhtml+xml, image/jxr, */*
Accept-Language: en-GB
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.79 Safari/537.36 Edge/14.14393
Accept-Encoding: gzip, deflate
Host: ccgi.dougrice.plus.com
DNT: 1
Connection: Keep-Alive
Cookie: Wiki=rev&1&id&3989&randkey&286140683
HTTP/1.1 200 OK
Connection: close
Cache-Control: no-cache
Pragma: no-cache
Content-Type: text/html; charset=utf-8
Content-Length: 211
<html><head><title>Request Rejected</title></head><body>The requested URL was rejected. If you think this is an error, please contact the webmaster. <br><br>Your support ID is: 18036279169218871260</body></html>
DNT: 1
Cookie: TS0194eee0=01a7d14f7fbd8ed2d93430826b98f227643c4c8933d30032c53e6ae7a0651d644e522f2cb9
HTTP/1.1 200 OK
Date: Sat, 20 May 2017 07:21:21 GMT
Keep-Alive: timeout=10, max=100
Set-Cookie: TS0194eee0=01a7d14f7fd89ac60e76d845ad9a2901104d9fae067996172d18ddd00d03531e030fd4d8b0; Path=/
Transfer-Encoding: chunked
<html>
<head>
<title>Test CGI output</title>
</head>
<body>
<h1>Test CGI output</h1>
<HR>
ARGS = <BR>
<H2>Environment variables</H2>
<pre>set DOCUMENT_ROOT=/services/webpages/c/c/ccgi.dougrice.plus.com/public
set GATEWAY_INTERFACE=CGI/1.1
set GDFONTPATH=/services/share/fonts
set HTTP_ACCEPT=text/html, application/xhtml+xml, image/jxr, */*
set HTTP_ACCEPT_ENCODING=gzip, deflate
set HTTP_ACCEPT_LANGUAGE=en-GB
set HTTP_CONNECTION=Keep-Alive
set HTTP_COOKIE=TS0194eee0=01a7d14f7fbd8ed2d93430826b98f227643c4c8933d30032c53e6ae7a0651d644e522f2cb9
set HTTP_DNT=1
set HTTP_HOST=ccgi.dougrice.plus.com
set HTTP_USER_AGENT=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/51.0.2704.79 Safari/537.36 Edge/14.14393
set MvCONFIG_LIBRARY=/services/websoftware/miva/Empresa/cgi-bin/libmivaconfig.so
set PATH=/sbin:/usr/sbin:/bin:/usr/bin
set QUERY_STRING=
set REMOTE_ADDR=212.56.108.219
set REMOTE_HOST=dougrice.plus.com
set REMOTE_PORT=55815
set REQUEST_METHOD=GET
set REQUEST_URI=/cgi-bin/tt.pl
set SCRIPT_FILENAME=/services/webpages/c/c/ccgi.dougrice.plus.com/cgi-bin/tt.pl
set SCRIPT_NAME=/cgi-bin/tt.pl
set SCRIPT_URI=http://ccgi.dougrice.plus.com/cgi-bin/tt.pl
set SCRIPT_URL=/cgi-bin/tt.pl
set SERVER_ADDR=91.136.8.9
set SERVER_ADMIN=or webmaster
set SERVER_DOMAIN=ccgi.dougrice.plus.com
set SERVER_NAME=ccgi.dougrice.plus.com
set SERVER_PORT=80
set SERVER_PROTOCOL=HTTP/1.1
set SERVER_SIGNATURE=
set SERVER_SOFTWARE=Apache
set no_gzip=1
</pre><HR>
</body>
</html>
Isn't the cookie separator a semi-colon (;) this may be the issue you have here as I notice the other entry uses these.
dougrice
If I clear the browser cache, it works, for a few goes.
It breaks when I do a post.with my password in it.
dougrice
I am not sure. I think it is a website issue. The main modiwiki works.
My Instance on PlusNet seem to be the ones breaking. They have worked for years.
dougrice
I spent some time clearing the cache and looking at the access logs on ccgi site.
As soon as a web page has the cookie below attached, it stops the CCGI server serving my PERL cgi scripts.
I can  access   .php and .htm pages okay. CGI scripts ending in .pl break, but work again after clearing the cache.
The access logs do not show the GET when it is rejecting the URL.
I tried using CARP to report any errors to browser, but this did help much.
The cgi does not have error log files, only access log files.
I am confused.
Using the preference link on the Wiki seems to be the trigger.
Clear the cache and the perl scripts start working. As soon as the wiki attaches the  cookie scripts seem to be rejected.
The Wiki has worked for a long time, and this behaviour has only started about a month or two ago.
spraxyt
Aspiring Legend
Fixes: 75
PHP was updated to version 5.6 a few weeks ago, but this should have no effect on Perl scripts, and didn't in my experience. I think Apache might have been updated around that time too, though that is just a guess. However if this was done it changed nothing for me.
The obscure error message you mentioned in the opening post means an error of some sort did occur but printing it on screen has been suppressed for security purposes. It might even mean there was a Server Error 500 which could result from something in .htaccess. Whilst the message suggests finding out the underlying cause is easy - just ask; unfortunately I think the system log is inundated with error messages like that so it isn't; Doing your own diagnostics is likely to be far quicker.
To this end you mentioned using Carp to get a clue. Was this by adding
use CGI::Carp qw/fatalsToBrowser/;
in the preface at the top of the Perl script?
David
dougrice
Hi David,
I have tried adding the CARP code. Unfortunately, it does not show anything.
It does seem related to when I open the preference link.
http://ccgi.dougrice.plus.com/cgi-bin/wiki_doug.pl?action=editprefs
I will need to add my own debug code and disable functionality then add it back until it breaks!
Once the cookie is attached, this and other perl scripts stop working. This suggests the script is left in a state that overloads the  CGI module for the next few GETS.
regards,
Doug
spraxyt
Aspiring Legend
Fixes: 75
After visiting that linked page then trying to go elsewhere on the site I've experienced the "invalid URL" problem. Deleting cookie dhrWiki makes it work again.
I think the problem is that cookies being transmitted as part of the headers means the cookie value needs to be URL encoded (which would encode the ampersands).. Doing Perl diagnostics is unlikely to show anything because the failure occurs before Perl is entered.
I haven't used cookies in Perl but my impression is that the CGI::Cookie Perl module does URL encoding for you. Do you use this or roll your own?
David
dougrice
Many thanks,
It seems that & in the cookie value breaks the web server.
I consider this to be a bug in the webserver, as the RFCs make no mention of avoiding & in the value. The RFC only talk about = and ;
One workaround is change the wiki.pl script to use a different value separator.
I changed the cookie to use _ instead of & as a value separator.
becomes:
Cookie: Wiki=rev_1_id_3989_randkey_286140683
Now when I try Microsoft Edge, it is not breaking the web server.
I have another workaround for updating the wiki which works.
The Wiki I use was downloaded from http://www.usemod.com/cgi-bin/wiki.pl?UseModWiki a very long time ago.
So may I thank all who have helped get a solution. 's last comment was very helpful.
I did say this 5 days ago.
dougrice
Hi Mook,
Thanks a well. I had a look on Wikipedia and the RFC and it mentioned = and ; and spaces.
So having & in the value between = and ; has not been a problem except in this case.
For this wiki, the value is a list.
I changed & to _ this morning and it did not trigger the problem.
Once the cookie is attached to a perl script served by the PlusNet CCGI server, the server is breaking, until the cookie is deleted.
By changing the cookie to use a different list separator, it now get around the CCGI server defect.
The expiry date in the CGI server was hard wired to a date in 2013. I am not sure who is suppose to deleted expired cookies!
There is probably an issue here to look into.
Thanks Smiley
spraxyt
Aspiring Legend
Fixes: 75
I extracted the cookie creation and setting code from the Wiki source into a small script and reproduced the "lockout" problem with this script.
However a test using a forms example from the CGI Perl Module distribution creates a cookie containing
Value: text&black&background&silver&name&David&size&3
and that works OK; returns the values and updates if preferences are changed. The obvious difference is that it contains text items - I'll pass on why that might be significant.
The expiry date set in the Wiki is '+3y' (3 years hence) and that's what my test showed. That date would normally be extended by the script on each access. To delete a cookie one supplies a date in the past. Browsers should remove expired cookies from their store. However the cookie store is regarded as a finite space and browsers may choose to remove cookies before they expire. users can also remove them.
Scripts are expected to cope with absence of state information due to missing cookies.
David
dougrice
Thanks for the reply. Interesting that you get the lock out. Without the error log, this is almost impossible to fault find.
I have another perl CGI-script tt.pl which makes no attempt to decode the cookie. It works until I use the wiki and it attaches this cookie.
It breaks until I delete the cookies. These GET requests are not in the access.log whil it is broken.
I have other perl scripts that also work until this cookie is attached.
When I delete the cookies by deleting the browser history they work again. I use Midori, Firefox, Edge and IE11. ( IE11 has a feature that when you tick all the boxes, you do not delete cookies for your favorates! )
I have a  work around.  I have another copy of wiki.pl renamed but pointing at the same database. I enabled edits by anyone without a password. Using FTP I can enable and disable execute permissions for this script. I can update my wiki. My wiki got "handbagged"  without a password back in 2011 by trollers putting links to products ( mostly handbags )  on my wiki and guest books.
This script has worked for years, but has just started to break the PlusNet CCGI server recently, after visiting the Preferences page and providing the correct password. It works on the Raspberry Pi still. Even the latest version breaks and the cookies code is different.
Many thanks, Doug
spraxyt
Aspiring Legend
Fixes: 75
Because the path in the problem cookie is set to "/" (which means all the site) nothing at all will work, irrespective of language until that cookie is removed.
Using a PHP script I've listed the response headers passed by my form script (which works). These are
HTTP/1.1 200 OK
Date: Tue, 30 May 2017 18:16:14 GMT
Server: Apache
Set-Cookie: preferences=text&black&name&&background&silver&size&;
   path=/; expires=Thu, 29-Jun-2017 18:16:14 GMT
Content-Length: 2596
Connection: close
Content-Type: text/html; charset=ISO-8859-1
(The Set-Cookie header is on a single line, I split it across two line above for readability.)
The values shown are default settings, my PHP script doesn't understand cookies.
If I do the same check with the wiki extract script I get
HTTP/1.1 200 OK
Date: Tue, 30 May 2017 18:47:13 GMT
Server: Apache
Set-Cookie: hashcookie=randkey&56074534&rev&1&id&1357;
   path=/; expires=Thu, 01-Jun-2017 18:47:13 GMT
Content-Length: 91
Connection: close
X-Pad: avoid browser bug
Apart the addition of an X-Pad header (i'm not sure what that is about) the structure of the two Set-Cookie lines seems the same to me.
David
