Sagem 2704n as WiFi Extender for BT Openzone
- Sagem 2704n as WiFi Extender for BT Openzone
- « Previous
- Next »
Re: Sagem 2704n as WiFi Extender for BT Openzone
26-08-2015 11:33 PM
26-08-2015 11:36 PM
wget http://192.168.1.109/original-plusnet-bcm-image-72731.bin
When your Apple says 0.0.0.0 its implying that its connecting to all the IP addresses available your computer. In this case its just happens to be 1 address.
27-08-2015 1:40 AM
(web password=admin)
In your opinion... was it all worth the effort?, because it probably did not go as smooth as I hoped it would.
27-08-2015 12:11 PM
The original firmware is back but after factory reset and chucking my username and password into router page I only get red light for Internet. Strangely with factory default [email protected] Internet light is solid green.
27-08-2015 12:19 PM
27-08-2015 12:40 PM
27-08-2015 2:00 PM
28-08-2015 11:34 AM
Hope that makes some sense. Thanks to all for the help, i'm back on the grid.
27-11-2016 7:41 PM
Sorry to bump an old thread but I found it very useful for my current open zone repeater project, I could really do with some advice though if you're still about?
I've almost got it all working perfectly except I can't access the btwifi landing page? It comes up with DNS problem. Strangely, I'm able to access every other BT website?
the configuration should be the same as yours as I used your configuration dump btw
kind regards, Richard
- « Previous
- Next »
