Sagem 2704n as WiFi Extender for BT Openzone
- Sagem 2704n as WiFi Extender for BT Openzone
Re: Sagem 2704n as WiFi Extender for BT Openzone
18-08-2015 9:57 PM
I grabbed these images as having no MAC address listed didn't seem right. Shouldn't there be an IPv4 address in image 1 also?
18-08-2015 10:37 PM
It seems its not updated its-self correctly with this software version. I think because its very new, the openwrt guys are still working out a few bugs.
Now saying that......
I just tried to reconnect to BTWiFi and I had the same problem you did!. Because I connected 2 routers together and the 2704N decided to switch off its DHCP.
So can I suggest.....
NETWORK > DHCP and DNS > and untick "Domain required" and tick "Authoritative". (Apply & Save)
connect to the BTWiFi and System > Reboot > Reboot.
Normally you do not need to reboot this software, but sometimes it helps.
I see you have a good 47% signal level, so that look like a very good position for your router.
18-08-2015 10:48 PM
Heres the config from my setup:
https://drive.google.com/open?id=0B4-Ln6UubyEeTHctbkFKUEZpX00
you can upload it (in its zipped format) to System > Backup.
And reconnect to the Wireless again.
> Reboot again to be sure.
If it does magicaly work, then I forgot to tell you something in the posts
19-08-2015 12:36 AM
Thanks so much for the help!
19-08-2015 12:52 AM
oooh XBoxOne this is only a guess (because I have an old XBox360), but try to login via the xbox's web browser first. Then hopefully Live should login. But this is only a guess.
19-08-2015 12:56 AM
I'm trying a method of logging in via virtual machine on MacBook then copying VM's MAC address into XBoxOne alt MAC address. Had success with this previously but intermittent signal strength was the deal breaker. Hopefully with this setup I might fare better. Cheers!
19-08-2015 2:05 PM
The reset button seems to have no effect and I've no idea what caused it. Haven't changed any settings on router since functioning last night.
Is the reset to default open-wrt firmware procedure different than the usual paper clip method?
Additionally I did notice painfully slow browsing speeds (let alone streaming anything) when connected, although connection was stable (a revelation for Openzone). Any suggestions for reset and increasing speed once fixed?
Just when it all looked like it'd work 😛
20-08-2015 4:35 AM
I'll respond soon.
20-08-2015 5:16 AM
Can you download a mini HTTP or FTP server for your MAC.
Download this F/W: https://drive.google.com/open?id=0B4-Ln6UubyEeMVM5eUZkLUV2M2M and place it in your HTTP/FTP folder. This is the same F/W but without the first 64K
Telnet to 192.168.1.1 and type:
cd /tmpWhen the command line comes back. Repower your box.
wget http://192.168.1.216/FAST2704N-squashfs-only-with-luci.bin
sync
dd if=./FAST2704N-squashfs-only-with-luci.bin of=/dev/mtdblock5 bs=65536
Then you can upload the zipped config again from the web interface.
if you have a FTP server instead: change the wget line to "wget ftp://192.168.1.216/FAST2704N-squashfs-only-with-luci.bin"
Of course, I am assuming your IP address is 192.168.1.216
Thats probably the easiest way to bring it back to its working state.
20-08-2015 5:37 AM
In the Network > Interfaces > (Lan & Wwan) > Edit > Advanced Settings.
Change the MTU's to 1024. You might find that increases the speed (as much as 20%)
After the change, disconnect / reconnect your ethernet so your Apple's MTU should change as well.
Another bad suggestion:
I'm not into that spectral analysis vodoo. But looking at this pdf
You could try to turn your router so one of the sides is facing towards the BTWiFi access point.
20-08-2015 9:46 AM
MTU changes made, fingers crossed for improvement!
Many thanks
20-08-2015 9:48 PM
With my router in this mode is there any use in port forwarding on the 2704n for XboxLIVE or would that only be applicable to the primary router/ due to Openzone's setup?
21-08-2015 12:53 AM
So this is a bit of guess work now.....
If you change the MTU's to something large again, like 1480. And change..
Network > WiFi > Edit > Advanced Setup
the Fragmentation Threshold to a small amount - 350 (this feels very counter-intuitive to me)
It should make smaller wifi packets, which can resend quicker when the errors occur.
I also noticed... in the WiFi section, the RX speed drops down really low (like 11Mbs) inorder to keep the connection stable. And to be honest I dont know how to change that.
It needs to be double or tripple the internet speed to get a good thoughput.
I think that we have reached the limit of the hardware/software.
Oh, no port forwarding on public WiFi like that - Sorry.
21-08-2015 9:42 AM
Thanks for the Port info, I figured it wouldn't be applicable for BT FON.
Great advice Matty. (Disaster notwithstanding) I'll limp to broadband line day no troubles.
All the best!
21-08-2015 1:09 PM
Frag Threshold changes resulted in no connection to Openzone.
MTU change did yield speed improvement though.
