OpenVPN
chenks76
All Star
Fixes: 12
OpenVPN
anyone here using OpenVPN?
installed server on windows 10 using this tutorial (https://community.openvpn.net/openvpn/w ... dows_Guide)
installed the client on my android phone, copied the certs across and it connects up OK.
the phone gets a 10.8.x.x. IP address.
all good so far it seems.
however, i can't seem to see any of my local network devices when connected to the VPN, which are on the 192.168.x.x IP range.
do i need to do some more config for this to work?
i'm using a billion 8800NL router (with the appropriate UDP port open).
81 REPLIES 81
Re: OpenVPN
This is normally done using the VPN's profile where you add the new local network and mask to the list of accessible networks but where or how it's done using this software I can't say. But knowing this might help.
chenks76
All Star
Fixes: 12
Re: OpenVPN
hmmmmm
the tutorial made no mention of that, but then i'm assuming the tutorial was to simply get the VPN working, which essentially it does.
Mml
Re: OpenVPN
If your subnet mask is 255.0.0.0 when connected to VPN then no wonder you cannot connect to devices on 192.168.x.x range. I would suggest either bringing these 2 ranges closer together - say, 192.168.1.x for LAN, 192.168.2.x for VPN, and use a subnet mask 255.255.254.0 - or create a bridged connection between VPN and LAN on your Win10 machine (of which I'm not too confident to advise, but in theory this is what is required).
chenks76
All Star
Fixes: 12
Re: OpenVPN
openvpn gave me no options to set IP and/or subnet.
IP 10.8.0.x
subnet 255.255.255.252
when connected to local LAN
192.168.1.x
subnet 255.255.255.0
mssystems
Re: OpenVPN
.252 is a 30 bit subnet mask, which means you have exactly two host addresses.  10.8.0.1 and 10.8.0.2.  That is not, in itself, a problem.
My experience with Open VPN is with Red Hat and Vyos/Vyatta rather than Windows.
Open VPN is presented as a routing interface, a little like a separate ethernet card.  Traffic from the localhost is sent via the loopback interface (127.0.0.1), to the routing table, which applies the subnet mask to the destination address in the packet header and forwards to the Open VPN interface on the encrypted subnet.
If you can reach the server and ping it's 192.168.1.x address, but can not reach other devices on the subnet, you need 'forwarding' to be enabled on the server and you need the devices on the local subnet to forward packets bound for the encrypted subnet, to the server.  That probably means adding an entry to the routing tables on those other devices.
The DOS commands,
>route print
>route add
Are your friends.
chenks76
All Star
Fixes: 12
Re: OpenVPN
whilst connect to the VPN on my mobile
local IP 10.8.0.6
i can't ping 192.168.1.50 (which is the local IP of the windows 10 system that is running openvpn).
i can't ping 10.8.0.1 (which is the VPN local IP of the windows 10 system running openvpn).
mssystems
Re: OpenVPN
There will be a config file on the server.  AIUI, on Windows it's named server.ovpn by default.
Look for  the line that starts
server
And is followed by an IP and mask.  You probably want to use
server 10.8.0.0 255.255.255.0
If there is a line which starts
server-bridge
You probably want to comment that out by inserting a semi colon ; in front of it.
And to connect to other devices on the 192.168.1.0 subnet, you would need
push  "route 192.168.1.0 255.255.255.0"
Ref. https://openvpn.net/index.php/open-source/documentation/howto.html#server
chenks76
All Star
Fixes: 12
Re: OpenVPN
in my server.ovpn file i have
server-bridge is already commented out
the push routes section has no current routes. i have added that line to the ovpn file.
i shall resart and see what happens.
chenks76
All Star
Fixes: 12
Re: OpenVPN
still no luck even after those changes.
Fixes: 586
Re: OpenVPN
Maybe this https://blog.remibergsma.com/2013/01/13/howto-connect-to-hosts-on-a-remote-network-using-openvpn-and... might help
chenks76
All Star
Fixes: 12
Re: OpenVPN
this is the connection log showing on phone when connected to VPN
chenks76
All Star
Fixes: 12
Re: OpenVPN
hmm, i would need to add a route on the windows 10 system? or on the router?
mssystems
Re: OpenVPN
Can you post your server config file?
I don't need to see any of the comment lines starting # or ;
I do need to see the server directives.
chenks76
All Star
Fixes: 12
Re: OpenVPN
these are all settings that aren't commented out
port 1194
proto udp
dev tun
ca "C:\\Program Files\\OpenVPN\\config\\ca.crt"
cert "C:\\Program Files\\OpenVPN\\config\\server.crt"
key "C:\\Program Files\\OpenVPN\\config\\server.key"
dh "C:\\Program Files\\OpenVPN\\config\\dh1024.pem"
ifconfig-pool-persist ipp.txt
keepalive 10 120
comp-lzo
persist-key
persist-tun
status openvpn-status.log
verb 3
