Plusnet Hub One
- Re: Plusnet Hub One
Re: Plusnet Hub One
19-11-2015 4:10 PM
Its probably better to go for a separate modem & router.
If Plusnet mess up the firmware on the modem or router, its cheaper to replace just one affected item.
Re: Plusnet Hub One
19-11-2015 4:20 PM
Re: Plusnet Hub One
19-11-2015 4:21 PM
Re: Plusnet Hub One
19-11-2015 4:41 PM
Full facilities on your modem (G.INP etc)
Decent full-featured Gigabit router
Good Wireless
Fairly cheap.
You won't find one.
Re: Plusnet Hub One
19-11-2015 7:46 PM
Quote from: vilefox What is a hub one?
Are you being a total plonker Jeremy or did you read the start of the thread and are having a larf?
Re: Plusnet Hub One
19-11-2015 7:50 PM
The first page just has a link that shows how to plug it into a telephone socket.
Re: Plusnet Hub One
19-11-2015 8:02 PM
the hub one fills some of those categories not that I would personally wish to have one at this current time
Re: Plusnet Hub One
20-11-2015 12:45 AM
Quote from: vilefox The first page just has a link that shows how to plug it into a telephone socket.
No
Re: Plusnet Hub One
20-11-2015 1:31 AM
Re: Plusnet Hub One
20-11-2015 8:31 PM
NE
Re: Plusnet Hub One
24-11-2015 1:30 PM
but when i view the ticket there is no update since i placed the order on the 12th, and i thought this wasn't being made available to us existing customers yet?
Re: Plusnet Hub One
24-11-2015 1:37 PM
These will still be engineer installs rather then self installs.
Re: Plusnet Hub One
24-11-2015 1:41 PM
dick:quote
Re: Plusnet Hub One
24-11-2015 1:55 PM
Re: Plusnet Hub One
24-11-2015 2:16 PM
Quote from: Matthew These will still be engineer installs rather then self installs.
what will the engineers be doing in the premises?
i assume simply plugging in the router? seems a waste of his/her time to just do that.
