OpenVPN
FIXED- Subscribe to RSS Feed
- OpenVPN
Re: OpenVPN
01-11-2016 2:04 PM
Try this. Comment out the lines, as shown and add the ifconfig-pool directive.
; ifconfig-pool-persist ipp.txt
; persist-tun
ifconfig-pool 10.8.0.33 10.8.0.46 255.255.255.0
Connect your client and check it get's an IP from the pool, with a 255.255.255.0 netmask, then try pinging the server gateway 10.8.0.1
Re: OpenVPN
01-11-2016 2:20 PM - edited 01-11-2016 2:22 PM
whatever that has done has made the server service to start on the windows 10 system
the openvpn server couldn't connect.
i have reverted and the service now starts and connects as previous.
Re: OpenVPN
01-11-2016 3:33 PM
Oh hell, you made me read my notes.
Essentially the problem you have is Open VPN is defaulting to the old "net30" topology which was supposed to be deprecated with Open VPN 2.3. Net30 was required by Windows clients, back in the early days - like for Windows NT 3.1
Have a look on your Open VPN server for a folder named "ccd" which is short for Client Configuration Directory. The Linux path is usually /etc/openvpn/ccd Not a clue where it is on Windows. Anyhow, inside you should find a file corresponding to the CN name on the client's certificate - Often, "client1" Post the contents, as the directives may override the server directive.
You should also be able to find a file called ipp.txt which contains persistent IP mappings, which are written dynamically the first time a client connects. Until you have the tunnel working, it's an idea to delete or rename ipp.txt, each time you restart the server.
Re: OpenVPN
01-11-2016 3:50 PM
Re: OpenVPN
02-11-2016 8:16 AM
Oh hell. Now I installed OpenVPN on a Windows 10 VM
You can have the server create an ipp.txt file by specifying a path
ifconfig-pool-persist "C:\\Program Files\\OpenVPN\\config\\ipp.txt"
You can adjust the log level to something more useful for debugging, by altering the verb and mute directives
verb 5
mute 20
I think I might have found your issue, in the sample configuration files. It looks like Windows defaults to net30 unless you specify the topology directive in the server config - The topology directive is deprecated on Linux and does not even get a mention on the man page.
topology subnet
Still waiting for my Android tablet to charge up but in the meantime, give the topology directive a go.
Re: OpenVPN
02-11-2016 10:03 AM
am i adding - ifconfig-pool-persist "C:\\Program Files\\OpenVPN\\config\\ipp.txt" ?
am i also adding verb 5 and mute 20 to the ovpn file?
what topology directive am i setting? again is this added to the server.ovpn file?
Re: OpenVPN
02-11-2016 10:15 AM - edited 02-11-2016 10:18 AM
From my understanding it is all of them with a topology directive of : subnet.
Also a quick question, when you are testing this from your mobile phone I assume you're not using your wireless connection but your phone's 3/4G connection?
Re: OpenVPN
02-11-2016 10:29 AM
ok i'm a bit confused about the topology and what to actually add to the server config file.
Re: OpenVPN
02-11-2016 10:45 AM - edited 02-11-2016 10:47 AM
Hi @chenks76, does this help:
port 1194 proto udp dev tun topology subnet ca "C:\\Program Files\\OpenVPN\\config\\ca.crt" cert "C:\\Program Files\\OpenVPN\\config\\server.crt" key "C:\\Program Files\\OpenVPN\\config\\server.key" dh "C:\\Program Files\\OpenVPN\\config\\dh1024.pem" server 10.8.0.0 255.255.255.0 ifconfig-pool-persist "C:\\Program Files\\OpenVPN\\config\\ipp.txt" push "route 192.168.1.0 255.255.255.0" keepalive 10 120 comp-lzo persist-key persist-tun status C:\\UserName\\OpenVPN\\Log\\openvpn-status.log verb 5 mute 20
Remember to write the status log (3rd line from bottom) to a directory with the correct permissions. You may want to create a Log subdir in the OpenVPN hierarchy.
Corrected typo.
Re: OpenVPN
02-11-2016 10:47 AM
should the 192.168.1.0 IP be pointing to something specific or just the base IP range.
Re: OpenVPN
02-11-2016 11:18 AM
Well to me that's an instruction to push requests to devices in this IP range so the base range makes sense to me as anything else would restrict the binding. This range is of course the same address range as your machines have. So I"m assuming here that the second interface on your OpenVPN server has an IP in this range.
Re: OpenVPN
02-11-2016 11:21 AM
Re: OpenVPN
02-11-2016 3:11 PM
tried pinging 192.168.1.53 and got no response.
also tried 192.168.1.50 (which is the local IP of the windows 10 system and no response either).
Re: OpenVPN
02-11-2016 3:24 PM
OK @chenks76 does the new log file tell you anything?
And you do have two physical network cards in the machine that's running OpenVPN with one bound to the server IP in the config and the other in the 192.168.1.XXX range?
What is the physical structure of this install?
02-11-2016 3:27 PM - edited 02-11-2016 3:59 PM
All working now.
Bit of a marathon of piecing together incomplete and outdated documentation
Windows 10 Open VPN Server configuration
Private Network (LAN)
Subnet: 192.168.1.0
Mask: 255.255.255.0
Router IP (default gateway) : 192.168.1.254
Open VPN Server : 192.168.1.50
---server.ovpn---
# Open VPN (2.3.12) server.config
port 1194
proto udp
dev tun
comp-lzo
ca "c:\\program files\\openvpn\\config\ca.crt"
cert "c:\\program files\\openvpn\\config\server.crt"
key "c:\\program files\\openvpn\\config\server.key"
dh "c:\\program files\\openvpn\\config\dh1024.pem" # not recommended. generate dh2048 for production
topology subnet
keepalive 10 120
persist-key
persist-tun
status open-vpn-status.log
client-config-dir ccd
ifcongfig-pool-persist ipp.txt
server 10.8.0.0 255.255.255.0 # the tunnel subnet
push "route 192.168.1.0 255.255.255.0" # your local subnet
; push "dhcp-option DNS 192.168.1.254" # uncomment to push private DNS sever, if you have one
# logging
; log "c:\\program files\\openvpn\log\\server.log
verb 5
mute 20
---end server.ovpn---
---client1.ovpn---
#Open VPN (2.3.12) unified configuration file
client
dev tun
proto udp
port 1194
remote myopnvpnserver.ddns.net #Public (WAN) IP or FQDN of router
comp-lzo
persist-tun
persist-key
keepalive 10 120
verb 1
<ca>
# contents of ca.crt from server
</ca>
<cert>
# contents of client1.crt from server
</cert>
<key>
# contents of client1.key from server
</key>
---end client1.ovpn----
Additionally,
+ Add a rule to the Windows firewall on the OpenVPN server to,
allow all traffic from the subnet 10.8.0.0 mask = 255.255.255.0
+ Add a port forward to the router
UDP 1194 -> 192.168.1.50
To reach other devices on the 192.168.1.0 subnet you will need to
+ Add a static route to the router,
interface = LAN, destination = 10.8.0.0, mask = 255.255.255.0, gateway = 192.168.1.50
+ Enable IP forwarding on the Windows Open VPN server
There is a registry hack but the easiest way is to enable the Routing and Remote Access service.
Alternatively, get yourself a Linux box, it's much easier ![]()
