Hub One Port Forwarding
Pete11
Seasoned Pro
Fixes: 4
Hi all, I'm looking for help on the hub1 and port forwarding please. I am a member of an online fishing simulator and need port 1808 open, but can't remember what I need to do to get this going. Embarrassed
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
11 REPLIES 11
Fixes: 1,484
Re: Hub One Port Forwarding
There's some help here https://community.plus.net/t5/Gaming/Plusnet-Routers-and-Port-Forwarding/td-p/1307971
Pete11
Seasoned Pro
Fixes: 4
Thanks for the reply.
I have done that and the ports still seem to be blocked somewhere. I cannot connect to any of the servers, when I try it says 'connection error, make sure the ip address is correct' which it is. Do I have to reboot router to complete the changes?
Pete11
Seasoned Pro
Fixes: 4
Well, 5 hours on and still can't open port 1808. Here's what I've done..and the results...screen shot 5 shows port still closed.
Fixes: 1,484
is the fishing app running when you test the port is open?
Pete11
Seasoned Pro
Fixes: 4
Yes it is, The port should be open to allow people who use the simulator to access a server to fish in matches, challenge's etc. and I can't seem to open it to take part. Hence the last shot of a port checker to see it's still closed.
Fixes: 1,484
and you're running the online match server?
Pete11
Seasoned Pro
Fixes: 4
No dvorak..not running it, just trying to get to fish the matches, the server is separate from the simulator, which needs the port open to gain access.
Fixes: 1,484
The port opening is only required if you're running the server.
You shouldn't need to open ports to join a game.
Pete11
Seasoned Pro
Fixes: 4
Sorry for late reply, and you are correct. I have been onto the admin/maker of the fishing sim and there was a problem on there side hence I couldn't connect to their server.
Thanks for your help though...and your time. Thumbs_Up
Fixes: 1,484
No worries, I would remove the port opening you have configured in your router now if you don't need it
Pete11
Seasoned Pro
Fixes: 4
Already seen to. Cool_smiley
