Hub One Port Forwarding
FIXED- Subscribe to RSS Feed
- Re: Hub One Port Forwarding
13-05-2017 1:08 PM
Hi all, I'm looking for help on the hub1 and port forwarding please. I am a member of an online fishing simulator and need port 1808 open, but can't remember what I need to do to get this going.
Growing old is inevitable...But growing up is optional.
Fixed! Go to the fix.
13-05-2017 1:49 PM
13-05-2017 2:24 PM
Thanks for the reply.
I have done that and the ports still seem to be blocked somewhere. I cannot connect to any of the servers, when I try it says 'connection error, make sure the ip address is correct' which it is. Do I have to reboot router to complete the changes?
13-05-2017 7:34 PM
Well, 5 hours on and still can't open port 1808. Here's what I've done..and the results...screen shot 5 shows port still closed.
13-05-2017 8:25 PM
13-05-2017 8:39 PM - edited 13-05-2017 8:40 PM
Yes it is, The port should be open to allow people who use the simulator to access a server to fish in matches, challenge's etc. and I can't seem to open it to take part. Hence the last shot of a port checker to see it's still closed.
13-05-2017 8:52 PM
13-05-2017 9:47 PM
No dvorak..not running it, just trying to get to fish the matches, the server is separate from the simulator, which needs the port open to gain access.
13-05-2017 9:52 PM
You shouldn't need to open ports to join a game.
14-05-2017 8:12 AM
Sorry for late reply, and you are correct. I have been onto the admin/maker of the fishing sim and there was a problem on there side hence I couldn't connect to their server.
Thanks for your help though...and your time.
14-05-2017 8:14 AM
14-05-2017 8:15 AM
Already seen to.
