How do I check how many devices I have Plusnet Protect loaded on
- How do I check how many devices I have Plusnet Pro...
17-07-2019 6:19 PM
Years ago when I first started using PlusNet Protect, there was a screen that showed me the devices I had the software loaded on. I think I may have outdated laptops registered and have just got a new laptop that I want to load the software on, but I can't seem to find the page in my account that shows me how many devices I have this loaded on. Does it still exist?
1 REPLY 1
Re: How do I check how many devices I have Plusnet Protect loaded on
18-07-2019 10:59 PM
Hi there.
Not sure there is a way check this from your account, do you have a computer still with Plusnet Protect installed on and are able to check from the McAfee control panel? Failing that feel free to PM me your account username and the best contact number to get you on and I’ll be happy to arrange for McAfee to call you to deactivate any unused licenses.
