How big is your Windows?
shutter
Fixes: 65
out of curiosity, I decided to check the "properties" of my HDD .... size 250 GB.... it shows less than 50GB free at present, which got me thinking ,... What have I really got on there  ? ? ?   so I thought I would check the properties of the Windows folder.... it shows as almost 23GB  !!  Shocked    is this "normal"     for WINDOWS 7 PROFESSIONAL
15 REPLIES 15
7up
Fixes: 17
Re: How big is your Windows?
Some people have all the luck Roll_eyes
screenshot_914
Browni
Aspiring Hero
Fixes: 60
25.2GB for Windows 7 Home Premium here.
Windows 10 Pro takes up 14.9GB but that's a relatively new install.
Pete11
Seasoned Pro
Fixes: 4
26.5 Gig here, Windows 7 Pro.
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
Legend
Fixes: 257
Windows 7HP - Windows file is 26.3GB
Fixes: 420
Is there by any chance a 'windows.old' folder holding a full previous version lurking somewhere? After a  major update of win 10 one is generated automatically and should disappear after a month. I can't remember if win 7 does the same.
shutter
Fixes: 65
 Hmm... interesting that I have the smallest windows ! ! ! ...
@Baldrick1    No sign of windows.old  file       but I do have a weird folder   as pictured...... I do hope it`s not a "nasty" although I have scanned it with Microsoft Security Essentials and it says no problem.
Legend
Fixes: 257
Not on W7, @Baldrick1, but even if there was it wouldn't still be on my system - I always trim junk off my main drive.
I can account for the size of my 'Windows ' folder, there's nothing in there that shouldn't be.
daveplus
Fixes: 10
Windows 10 1803: 29.6GB, 26.5GB on disk, 114,597 files
Fixes: 420
Windows 10 Pro 1803
@shutter
If you Google it, several people are asking about dbus-keyrings across a range of platforms. Sorry I have no idea what it is.
shutter
Fixes: 65
@Baldrick1  OK  Thanks.... Why don`t  I ever think of that   ! ! !! Cheesy
7up
Fixes: 17
Forget willy waving, it seems window waving is the new trend these days..
billnotben
HP Windows 7 home premium
7up
Fixes: 17
Seeing as we've wandered right away from 7 pro as @shutter asked for... here's my 7HP:
screenshot_825
daveplus
Fixes: 10
The Windows folder in my Windows 7 Pro on VMware is 26.5GB and contains 142,028 Files,
