How big is your Windows?
- Re: How big is your Windows?
28-05-2018 11:39 PM
out of curiosity, I decided to check the "properties" of my HDD .... size 250 GB.... it shows less than 50GB free at present, which got me thinking ,... What have I really got on there ? ? ? so I thought I would check the properties of the Windows folder.... it shows as almost 23GB !! is this "normal" for WINDOWS 7 PROFESSIONAL
29-05-2018 1:35 AM
Some people have all the luck
29-05-2018 3:36 AM
25.2GB for Windows 7 Home Premium here.
Windows 10 Pro takes up 14.9GB but that's a relatively new install.
29-05-2018 5:46 AM
26.5 Gig here, Windows 7 Pro.
Growing old is inevitable...But growing up is optional.
29-05-2018 7:58 AM
Windows 7HP - Windows file is 26.3GB
29-05-2018 9:45 AM - edited 29-05-2018 9:45 AM
Is there by any chance a 'windows.old' folder holding a full previous version lurking somewhere? After a major update of win 10 one is generated automatically and should disappear after a month. I can't remember if win 7 does the same.
29-05-2018 10:53 AM - edited 29-05-2018 10:54 AM
Hmm... interesting that I have the smallest windows ! ! ! ...
@Baldrick1 No sign of windows.old file but I do have a weird folder as pictured...... I do hope it`s not a "nasty" although I have scanned it with Microsoft Security Essentials and it says no problem.
29-05-2018 11:30 AM
Not on W7, @Baldrick1, but even if there was it wouldn't still be on my system - I always trim junk off my main drive.
I can account for the size of my 'Windows ' folder, there's nothing in there that shouldn't be.
29-05-2018 11:32 AM
Windows 10 1803: 29.6GB, 26.5GB on disk, 114,597 files
29-05-2018 12:09 PM
Windows 10 Pro 1803
If you Google it, several people are asking about dbus-keyrings across a range of platforms. Sorry I have no idea what it is.
29-05-2018 12:19 PM
@Baldrick1 OK Thanks.... Why don`t I ever think of that ! ! !!
29-05-2018 1:43 PM
Forget willy waving, it seems window waving is the new trend these days..
29-05-2018 1:54 PM
HP Windows 7 home premium
29-05-2018 2:22 PM
Seeing as we've wandered right away from 7 pro as @shutter asked for... here's my 7HP:
29-05-2018 3:36 PM
The Windows folder in my Windows 7 Pro on VMware is 26.5GB and contains 142,028 Files,
