Captive wifi
pvmb
Champion
Fixes: 17
Re: Captive wifi
You also may need to check on the user's PC what the settings are for the Network DNS.
VH3
Re: Captive wifi
Is there anyway Plusnet can look directly at the router from their end?
VH3
Re: Captive wifi
They don't have a PC only an iPad and phone
Re: Captive wifi
Can I suggest you use file attachments, as images have to be approved..
Fixes: 389
Re: Captive wifi
@VH3 No, I don't think PN  can directly interrogate your router.
To attach an image on a phone. you need to change from the mobile to desktop view.
pvmb
Champion
Fixes: 17
Re: Captive wifi
Can you go to the PN router's My devices page and see if there is any record of unknown devices having been connected. List should show under "Device name".
What I don't understand is, if a device has been logged on to a Wi-Fi source once it should retain the Wi-Fi credentials and just log on automatically next time, until told to 'Forget' them.
VH3
Re: Captive wifi
There is nothing there to upload an attachment, no paperclip or anything else for me to click on!
Fixes: 389
Re: Captive wifi
@VH3 - see post #20
VH3
Re: Captive wifi
This is the page it brings upThis is the page it brings up
pvmb
Champion
Fixes: 17
Re: Captive wifi
...Never seen that before! Is that a PN router manual set-up page?
VH3
Re: Captive wifi
@pvmb message #21
That's what I would have thought but it's not working. The stupid thing is , I'm using the WiFi connection on my phone and it's working ok.
Just had a 'lightbulb' moment. My phone is Android, the in-laws connection is on an iPad. Would it be something in the Apple settings?
Fixes: 389
Re: Captive wifi
no - that is the account log-in page.
Fixes: 389
Re: Captive wifi
@VH3 wrote:
@pvmb message #21
Nothing to do with Apple settings.
pvmb
Champion
Fixes: 17
Re: Captive wifi
...Online account log in page is what it looks like to me! But PLUSNET-QWC93Q is simply a PN router supplied default wireless network name ID. But you wouldn't normally log on to Wi-Fi with the PN online account details.
I wouldn't know about Apple stuff, how about you?
Fixes: 389
Re: Captive wifi
@Dan_the_Van That screenshot looks 'odd' to me.
I still think there is some malware/virus involved here, or the in-laws have inadvertently been on a dodgy site.
