Press the Button pleeeaasseeee :)
- Feedback
- Plusnet Feedback
- Re: Press the Button pleeeaasseeee :)
10-03-2011 3:28 PM
![Roll_eyes Roll_eyes](/html/@7617B13E24C0CCAE119AD01B2BB73839/images/emoticons/rolleyes.gif)
10-03-2011 4:25 PM
![Wink Wink](/html/@0FA1396AC0773F33E2DC472BB4F75D3C/images/emoticons/wink.gif)
10-03-2011 4:52 PM
![Huh Huh](/html/@3681646702FDFD32BCA97E2E5F1BDDD5/images/emoticons/huh.gif)
![Sad Sad](/html/@6BD5E1FD9194A889D807C8E641344CF1/images/emoticons/sad.gif)
![Cry Cry](/html/@EF02202129013B5A91517CA3B2B0F58A/images/emoticons/cry.gif)
10-03-2011 6:14 PM
10-03-2011 6:15 PM
10-03-2011 6:27 PM
Quote from: BEERMAN684 ------- Everyhting is connected
When you said everything connected was you referring to your equipment or did you have the broadband light on? If it's the former and you did not have the broadband light on then it's not a case of flicking a switch as the work in the exchange may not have taken place. What date was you given for your broadband?
10-03-2011 6:33 PM
10-03-2011 6:42 PM
10-03-2011 7:17 PM
Quote from: itsme Have your modem got a separate broadband and internet light? If you have broadband and no internet then this is down to PN flicking a switch. Are you using a PN supplied modem? Have you checked the Username and password in the modem settings?
I have a Thompson router/modem as supplied by plusnet, It has a seperate internet and broadband lights. The broadband light just flickers/ flashes continuasly. No indication whatsover of the internet light coming on. I have set up the username as beerman etc etc etc and enterd the password as requested. rebooted everything after it dident work and even after that the broadband light is still just flickering
10-03-2011 7:22 PM
10-03-2011 7:33 PM
10-03-2011 7:49 PM
Your router *should* have been configured for easy start so that left to its own devices the router would have connected to Plusnet and configured itself within 10 minutes or so, no need for any user set-up at all.
What entries appear in the router log which you can find here?
10-03-2011 7:51 PM
10-03-2011 7:58 PM
Quote from: spraxyt When you made the opening post in this thread, saying "everything was connected" was the broadband light solid green? If BT had completed installation you should have been able to get to that stage without Plusnet "pushing any buttons". Then the right-hand Internet light would flash, and "pushing buttons" enables it to complete authentication and become solid green. (Flashing during data transfer is normal.)
pm send to you, thank you for the help.
10-03-2011 8:01 PM
