Plusnet Protect
CharlieSmirke
Plusnet Protect
Has anyone else received an email today informing them that their Plusnet Protect has been cancelled for no reason? I got in touch and the best answer was to uninstall and install but the email says if I still have it running to uninstall it now. I don't want to uninstall and then not be able to get it back cos its cancelled! Any ideas?
109 REPLIES 109
adamwalker
Fixes: 221
Re: Plusnet Protect
Hi CharlieSmirke,
FYI We are aware of others affected by this, problem 64480 is already open and we're currently looking into this. I believe you should be fine to reinstall but please hang fire until I've gained some clarification.
Adam.
 Adam Walker
CharlieSmirke
Re: Plusnet Protect
Cheers-but am I still protected now (as best I can be with McAfee) or has it actually been cancelled? Will I still get updates?
adamwalker
Fixes: 221
Re: Plusnet Protect
This is what I need to gain clarification on, please bear with me as we need to do a little investigation before I can confirm that.
 Adam Walker
gswindale
Re: Plusnet Protect
Don't appear to have got that particular email, but I did get a notification from the control panel asking me to renew last night.  Clicked the link and just got taken to the PN homepage.
Dom
Re: Plusnet Protect
If it's a decent, free, light-weight, and easy-to-use anti-virus package you're all after, then I'd suggest Microsoft Security Essentials. I've been using it since it was released and have no troubles at all. It's received good reviews as well.
Smiley
adamwalker
Fixes: 221
Re: Plusnet Protect
that link seems to be broken Dom.
 Adam Walker
Dom
Re: Plusnet Protect
Not for me it isn't. Huh
Lemme check it again...
...nope, working fine for me. Checked in Chrome and Firefox.
Strat
Fixes: 565
Re: Plusnet Protect
Works for me too.
adamwalker
Fixes: 221
Re: Plusnet Protect
Works fine for me now, odd...
 Adam Walker
adamwalker
Fixes: 221
Re: Plusnet Protect
Hi all, just to clarify your Mcafee should be working fine and allow you to reinstall its the system that sends notifications that's at fault here so the service itself should be unaffected.
 Adam Walker
gswindale
Re: Plusnet Protect
Does that apply in my case as well - I'm just being notified that I need to renew it.
I'd rather not have to uninstall & reinstall if at all possible.
adamwalker
Fixes: 221
Re: Plusnet Protect
If you've not received a notification you've not been affected, simple as that really. There's no other affects of this problem other than a few customers being sent irrelevant messages.
Adam.
 Adam Walker
gswindale
Re: Plusnet Protect
ok, but how do I get rid of the constant "renew now to stay protected" message?
pierre_pierre
Re: Plusnet Protect
sounds like PN got it off the back of a magazine and forgot to renew after the end of the trail period Crazy Crazy Roll_eyes
