Plusnet Protect
stallan
Re: Plusnet Protect
Yep - happened to me now. Just started up the family PC the message appeared.
adamwalker
Fixes: 223
Re: Plusnet Protect
ok, but how do I get rid of the constant "renew now to stay protected" message?
I need to confer, keep closing them for now and I will come back with more info ASAP.
 Adam Walker
CharlieSmirke
Re: Plusnet Protect
Just got home after a phone call from PN telling me to sort the problem out I need to uninstall and re install. As you can see from my initial email I was very dubious about doing this but hey they're the experts. Uninstalled and ,of course, Mcafee won't let me install on this account. I hate to say I told you so but I told you so.
adamwalker
Fixes: 223
Re: Plusnet Protect
PS geofftswin,
Can you drop me a PM with your account username, adding your account details to the problem may help speed up the investigation process.
 Adam Walker
adamwalker
Fixes: 223
Re: Plusnet Protect
 Adam Walker
stallan
Re: Plusnet Protect
Uninstalled and re-installed but this fails (see screenshot)
CharlieSmirke
Re: Plusnet Protect
Re Stallan - thats the one, yes.
Oldjim
Resting Legend
Fixes: 63
Re: Plusnet Protect
I thought this was a multiple user license - is it only one licensed install per customer
stallan
Re: Plusnet Protect
Shouldn't be as I had it installed and working on at least 2 PCs.
I thought it was up to 7 PCs.
On the PC I had to remove it from, I've slapped AVG 2011 on and it's now running a full scan (god knows when it will finish). Now I need to check out the other PCs in the house before their owners get home  Wink
adamwalker
Fixes: 223
Re: Plusnet Protect
To clarify we seem to have had 2 issues at play. The first which CharlieSmirke reported has now been resolved and was a minor issue at our side only affecting very few individuals. As for the others amongst you that have been affected the issue lies with Mcafee I'm afraid, this has been reported to them so I will let you all know when progress is made.
 Adam Walker
CharlieSmirke
Re: Plusnet Protect
Re Adam Walker- I'm glad you think its a minor issue. I haven't known for almost 24 hours now wether or not my pc is protected. I've had advice from 3 different PN staff members, including yourself, all telling me the same thing which I followed and its the problem that caused which is waiting to be resolved = hopefully.
adamwalker
Fixes: 223
Re: Plusnet Protect
That was a comment about the impact on our customers in general, I was in no means playing down the effect on you as an individual.
We're sorry for any inconvenience this may have caused you, please try reinstalling everything should be fine from there.
Adam.
 Adam Walker
Dom
Re: Plusnet Protect
Quote from: CharlieSmirke
... I haven't known for almost 24 hours now wether or not my pc is protected...
You're unlikely to be vulnerable to any nasties anyway to be honest. Unless you regularly visit sites you don't know, or visit as many porn sites as you can find, then you're highly unlikely to run into any troubles. Especially if it's only been 24 hours. In fact, after 24 hours, if there's a virus out there that you're not protected from, it'd take longer than that for your AV suppliers to come up with a new definition to protect you anyway.
The PN team might not be able to "play down" your problem for PR reasons or whatever, but I can, and at this point you're worrying about nothing. I don't think you'll pick up a virus that you're not already protected from, and any viruses etc that have been made since your AV last updated could affect you regardless of whether you have the latest definitions anyway.
But like I mentioned on the first page, if you're that worried about it, try Microsoft Security Essentials. I've heard nothing but good things, and have used it myself for yonks.
Smiley Smiley
Oldjim
Resting Legend
Fixes: 63
Re: Plusnet Protect
Quote from: Dom
That really isn't too accurate. All the modern AntiVirus solutions use a variety of techniques to check for viruses and signatures are no longer the only part of the protection - heuristics are coming much more to the fore.
Frankly if the anti virus is totally disabled and not just stopped downloading updates I would be very concerned although, as you say, if you stayed clear of dodgy sites he may well get away with it.
However the first thing to do is a full scan to pick up any potential nasties
BUT - the fact that the first you knew about the cancellation is the email then you were almost certainly still protected otherwise the Windows Security warning would have leapt into action and warned you that your anti virus is disabled
gswindale
Re: Plusnet Protect
Quote from: _Adam_Walker_
PS geofftswin,
Adam - PM sent (hopefully!)
