Plusnet - New Network
bill888
Champion
Fixes: 40
Re: Plusnet - New Network
Is Plusnet still sending out notifications ahead or after switching a customer to the new Network?
My router unexpected rebooted early this morning, and I notice traceroute no longer lists the familiar gateways.
Tracing route to ntp.plus.net [212.159.6.10]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms home [192.168.1.254]
2 * * * Request timed out.
3 7 ms 7 ms 7 ms 133.hiper04.sheff.dial.plus.net.uk [195.166.143.
133]
4 7 ms 7 ms 7 ms be3-3102.pcn-ir02.plus.net [195.166.143.132]
5 8 ms 8 ms 7 ms be1.pcn-ir01.plus.net [195.166.129.160]
6 7 ms 7 ms 7 ms cdns02.plus.net [212.159.6.10]
When I manually disconnect and reconnect PPPoE session, I notice my WAN IP address changes but stays in the same 209.93.178.xxx subnet.
Looks like I am on the new Network ?
bobpullen
Fixes: 330
It was never our intention to, although some notices have been sent in error.
Yes, you are.
bill888
Champion
Fixes: 40
I just ran a speed test and it is returning 57 mbps download.   I am on legacy 40/20 product.
The bookmarked page:    https://portal.plus.net/my.html?action=data_transfer_speed
shows my 'Current speed' is '40 Mb'
I presume this is only a temporary technical glitch, and it may return to 40mb later.  In the  mean ttime, I presume I won't be charged extra for the unwanted speed boost.
MauriceC
Resting Legend
Fixes: 17
@bill888  As you are now on the new network, you may need to be aware of potential issues with the IP address range 209.93.x.x   (and others).  See this thread.   Optimistically you will not have a problem - it depends on the sites you visit.
bobpullen
Fixes: 330
Will look into that.
Riza
I don't think I'm on the new network; I'd imagine a lot has been going on since I checked the forums, but could you confirm if I'm on the new network?
Here's my trace-route.
1 1 ms <1 ms 1 ms router.asus.com [192.168.1.1]
2 19 ms 28 ms 15 ms lo0-central10.pcl-ag04.plus.net [195.166.128.185]
3 15 ms 15 ms 15 ms link-a-central10.pcl-gw01.plus.net [212.159.2.172]
4 15 ms 14 ms 17 ms xe-0-2-0.pcl-cr01.plus.net [212.159.0.204]
5 15 ms 15 ms 15 ms po2.pcl-gw01.plus.net [195.166.129.41]
6 15 ms 15 ms 15 ms cdns02.plus.net [212.159.6.10]
Trace complete.
I think those on the new network has the IR entries?
Thanks, Wink
spraxyt
Resting Legend
Fixes: 75
Unless you have a static IP that will be the old network.
I'm not sure what traceroutes look like for those on the new network with static IPs.
David
Luzern
Fixes: 9
Am I on it now?
Microsoft Windows [Version 10.0.10586]
(c) 2015 Microsoft Corporation. All rights reserved.
C:\Users\Gordon>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.244.22]
  1     1 ms     1 ms    <1 ms  home.gateway.home.gateway [192.168.1.254]
  3     *        *        *     Request timed out.
  4    10 ms    10 ms    11 ms  be3-3104.psb-ir01.plus.net [195.166.143.136]
  5    11 ms    10 ms    10 ms  core1-BE1.southbank.ukcore.bt.net [195.99.125.130]
  6    11 ms    11 ms    10 ms  peer2-et-2-1-0.telehouse.ukcore.bt.net [62.172.103.21]
  7    12 ms    12 ms    11 ms  194.74.65.42
  8     *        *        *     Request timed out.
  9     *        *        *     Request timed out.
 10    11 ms    10 ms    11 ms  ae0.er01.telhc.bbc.co.uk [132.185.254.109]
 11    12 ms    12 ms    12 ms  132.185.255.148
 12    12 ms    12 ms    12 ms  bbc.co.uk [212.58.244.22]
Trace complete.
Only on Thurs evening SNR increased from tweaked 3 dB, down speed dropped but up rose beyond the normal 888 kbps,
interleaving was removed. Ping has dropped two-thirds.
SpendLessTime
Fixes: 86
Yes, if the gateway has the letters IR in it as the tracert seems to show.
psb-ir01.plus.net
Check your gateway here
http://users.plus.net/@gateway_custom?debug-ip=yes
spraxyt
Resting Legend
Fixes: 75
Yes, that trace shows you are on the new network.
Visiting http://usertools.plus.net/@gateway/ should tell you that you are on psb-ir01 in the Southbank Point of Presence which means "new network".
David
bobpullen
Fixes: 330
@Riza, no you're not on the new network. Give away is the fact that you're routing through an 'ag' gateway.
Oldjim
Resting Legend
Fixes: 63
The post by Dave answers one question
When I put my IPAddress in https://www.iplocation.net/ it showed a number of connections from my part of England which presumably is on the same BRAS
RPMozley
Seasoned Pro
Fixes: 16
One odd thing I've seen on the 'new' network, is trying a connectivity check on the tg582n will always fail as the gateway IP address appears to be the wrong one. It's not the same as appears when running a trace route.
That's RPM to you!!
ejs
Aspiring Hero
Fixes: 25
It's not the wrong address, it's that the gateways with addresses like 172.16.10.5 don't respond to pings and won't show up in a traceroute either.
traceroute to community.plus.net (46.19.168.229), 30 hops max, 60 byte packets
 1  gateway (192.168.0.1)  4.472 ms
 2  * <-- this is where 172.16.10.5 would be if it responded to the traceroute probes
 3  *
 4  be3-3102.pcn-ir02.plus.net (195.166.143.132)  24.864 ms
RPMozley
Seasoned Pro
Fixes: 16
It's not that it doesn't respond to pings @ejs, it's completely different. Router reports 195.166.130.254 as the gateway IP but second hop on trace route shows 84.93.253.112
Then the tg582n reports no connectivity to the first IP when running the check.
That's RPM to you!!
