Absolutely the worst excuse for customer 'service' in UK history
- Feedback
- Plusnet Feedback
- Re: Absolutely the worst excuse for customer 'serv...
Re: Absolutely the worst excuse for customer 'service' in UK history
06-08-2017 1:49 PM
Is there any known cause of your supplier's test system repeatedly failing for a particular user as here ... which you guys have the ability to rectify please?
08-08-2017 2:10 PM
We've been flagging examples of the further diagnostics speedtest failing through and will continue to do so along with asking for the root cause to be investigated.
09-08-2017 11:24 PM
Still appallingly slow connection, still no help whatsoever from plusnet
10-08-2017 8:52 AM
Have you raised a fault report?
10-08-2017 9:11 AM
Thought I would try again, looking at this subject, a BT Speedtest. My speed is what I expect but the result is
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
12-08-2017 11:04 AM
For what it's worth, which is nothing, I have indeed raised a fault report, and have still heard nothing from the most disgraceful and utterly worthless 'service' providers in the UK.
12-08-2017 11:20 AM
12-08-2017 12:03 PM
If that is how you feel then your best bet is to move elsewhere, but personally I have praise for the staff they do a good job and I say that with conviction having been with Force9 for 15 years.
12-08-2017 1:16 PM
If it were that simple to leave this worthless excuse for a company I wouldn't be here complaining about it.
It's worse than a joke.
12-08-2017 2:56 PM
Have you tried Ookla Speedtest http://www.speedtest.net/ as an alternative test if so what are the results? Have you tried resetting the router as per the instructions?
If you stopped the bickering and responded in a more pleasant manner you may then obtain better results. But responding the way you are doing just gets peoples backs up and then you get by-passed because of the responses you are giving.
12-08-2017 4:02 PM
The Ookla speedtest is fine , but you need to use the BT tester as it sends the results to BT and PN to check
12-08-2017 4:55 PM
Quite understand but when you get
Then try another speedtester (Ookla) to see what your speed is which may be fine. Currently mine shows 39.48 down and 13.81up with Ookla but only 19.46 down 12.05up with BT and of course unable to report it to plusnet because of above. The fault, if you look through previous posts on BTW performance test, this has been faulty for this year with me and according has never performed correctly. Ookla does give you the benefit of what speed you think you should be getting although I should be getting around 58down and 14up but I am not ranting and raving about it.
12-08-2017 9:26 PM - edited 13-08-2017 10:10 AM
Unfortunately here their test for this user on their line fails. I suspect that this would be the same irrespective of who is the isp,
Sight of the router stats would be helpful.
13-08-2017 8:46 AM
Apologies if you think I was missing the point. I have had the BT speed test problem for nearly a year now albeit intermittent so when this happens I use Ookla really for peace of mind but also I check the connection speed in the router.
The point I was trying to make was, and I agree with you about the isp, is that it is a BT problem not PN and therefore it is out of PN's hands so to speak and ranting and raving regarding PN because of this is really not correct.
Router stats would be helpful as would router speed.
13-08-2017 12:52 PM
Hi guys
If anyone is unable to complete the further diagnostics, in order to further investigate, our suppliers would need the date and time the test was run, as well as the error message received.
Please send me a private message with this and I'll pass it on to BT.
Thanks in advance.
Anoush
- Feedback
- Plusnet Feedback
