firmware not updated
ar
My firmware is stuck on 4.7.5.1.83.8.237.2.2...is there a way to push the latest update
12 REPLIES 12
HarryB
Fixes: 256
Re: firmware not updated
Welcome to the community forums @ar
Based off a post from Bob Here, I'm not sure this is a problem or that the firmware is 'stuck' as such.
bobpullen wrote:
4.7.5.1.83.8.237.2.2 - Current version in live deployment
4.7.5.1.83.8.259 - Version being shipped with new units
4.7.5.1.83.8.259.1.1 - Version we have upgraded about 1/4 of live devices to
Are you experiencing any particular problem with your router currently?
 Harry Beesley
ar
Not recently . Wanted the latest update as I thought it is stuck as it did not update automatically ( given previous responses).
OskarPapa
Fixes: 65
Hi @ar, thanks for your response.
As you're using the latest (released) firmware I'd say that your best bet is going to be to wait until the next release automatically updates to the router, especially with you not experiencing any issues.
There is, however, a thread here that you're able to post in and request and update, should you wish.
bobpullen
Fixes: 316
@ar, are the last few digits of your router's serial number '853'? If so, it's not correctly registered on our hardware management platform which will stop updates getting to you. I've re-registered the device at our side, so a factory reset should sort this out.
ar
hi bob - no the last 4 digits are 3754
MatthewWheeler
Fixes: 480
We can see a entry where the last 4 digits are 3574? Is the above a typo? If not can you PM me the full serial number
 Matthew Wheeler
bobpullen
Fixes: 316
@ar, if it is '3574' then can you please factory reset your router by inserting something into the pinhole at the rear until the status light flashes green. Once this is done, it should allow me to communicate with the device.
ar
hi - here is the complete serial number +081441+NQ74803574...i have reset router couple of days back..pls let me know if you cant access it
bobpullen
Fixes: 316
@ar, you need to factory reset the device again to force a re-activation. The last time you did it, we hadn't made the necessary amendments at our side.
ar
Hi Bob - Just reset it again. Can you pls check
bobpullen
Fixes: 316
All sorted. Your device will be going for a reboot to apply the update.
ar
All done Bob. Many thanks. Cheers
