firmware not updated
- My Router
- Re: firmware not updated
25-12-2018 1:40 PM
My firmware is stuck on 4.7.5.1.83.8.237.2.2...is there a way to push the latest update
25-12-2018 3:43 PM
Welcome to the community forums @ar
Based off a post from Bob Here, I'm not sure this is a problem or that the firmware is 'stuck' as such.
bobpullen wrote:
4.7.5.1.83.8.237.2.2 - Current version in live deployment
4.7.5.1.83.8.259 - Version being shipped with new units
4.7.5.1.83.8.259.1.1 - Version we have upgraded about 1/4 of live devices to
Are you experiencing any particular problem with your router currently?
25-12-2018 6:13 PM
26-12-2018 9:10 AM
Hi @ar, thanks for your response.
As you're using the latest (released) firmware I'd say that your best bet is going to be to wait until the next release automatically updates to the router, especially with you not experiencing any issues.
There is, however, a thread here that you're able to post in and request and update, should you wish.
09-01-2019 1:24 PM - edited 09-01-2019 1:25 PM
@ar, are the last few digits of your router's serial number '853'? If so, it's not correctly registered on our hardware management platform which will stop updates getting to you. I've re-registered the device at our side, so a factory reset should sort this out.
12-01-2019 3:08 PM
hi bob - no the last 4 digits are 3754
13-01-2019 11:28 AM
13-01-2019 12:13 PM
@ar, if it is '3574' then can you please factory reset your router by inserting something into the pinhole at the rear until the status light flashes green. Once this is done, it should allow me to communicate with the device.
13-01-2019 5:24 PM
hi - here is the complete serial number +081441+NQ74803574...i have reset router couple of days back..pls let me know if you cant access it
14-01-2019 7:31 AM
@ar, you need to factory reset the device again to force a re-activation. The last time you did it, we hadn't made the necessary amendments at our side.
14-01-2019 8:18 AM
14-01-2019 8:56 AM
All sorted. Your device will be going for a reboot to apply the update.
14-01-2019 9:00 AM
