Empire
is there any alternative to the BT Smart Hub 6 Business on the horizon?    To use Plusnet
Ben1
Gah, it's happened again. Solid orange light on the BT Hub6, so again I'm temporarily back to the old Plusnet Hub1 (so I'm getting internet). I'm sure I read of the way to obtain a Hub2 from Plusnet? Is this my best option?
Thanks.
Fixes: 480
@Ben1
When your contract is up for renewal then ring the customer options team on 0800 013 2632 and ask for one. Alternatively you can pay about £100.
Personally I would have thought that reconnecting the Smarthub was less hassle than returning to a Hub 1.
Ben1
I see, I think I will take the first option in that case. I will follow my own procedure from a few weeks ago. Many thanks
Ben1
Up and running now, many thanks again
Ben1
…and again! No service on broadband. Both routers (Plusnet Hub 1 and BT 6) I’ve tried separately aren’t progressing past the orange light stage. I’m wondering if it’s the phone line or something.
Ben1
I have gone though the connection process but I couldn't connect. I will try again tomorrow when I will be fresh.
willcutforth
Fixes: 113
@Ben1 I can see you are back up and running now, is that the case?
 Will Cutforth
Ben1
Yes! I forgot to post back. All is fine now.
willcutforth
Fixes: 113
Awesome, no worries, you know where we are if you need anything else.
 Will Cutforth
Empire
Hi
My BT Business Smart Hub 6 - Type A   - BT BHub6      has  3 ethernet ports +  one Red WAN port.   and one J11 Telephone/Broadband port
Can this Router be used to connect to Virgin BT  FTTP ?
Fixes: 392
@Empire Virgin or BT ?- they are totally different networks and it won't work on Virgin.
Empire
My BT Smarthub 6 router definitely  works on BT  but would like to know is can that/this router work on BT or Plusnet FTTP  and/or any other networks
i have unlimited fibre with Plusnet  it works on that perfectly.
Fixes: 392
Ah, a slightly easier one to answer. yes, it will work on Plusnet connections (FTTC or FTTP), but not on Virgin/Altnets. AFAIK, but @Baldrick1 is the best one to confirm this, it will not work on other ISPs running over the OpenReach network, either.
Fixes: 480
@Empire
It all depends on the model of Smarthub 6. If it has four yellow LAN sockets then it will not work on full fibre. If it has 3 yellow LAN sockets and one with a RED label saying WAN then it will work on a BT or Plusnet service if you use that socket to connect to the ONT.
