Modem Update
neilru
Modem Update
I put in a request through a support agent on chat, last week, to get an update pushed to my hub one router - but nothing has changed.
Its still Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated 17/03/18
Is there is a new firmware? where can i find it?
7 REPLIES 7
MJN
Fixes: 5
Re: Modem Update
For what it's worth I've just received a new Hub One and it came installed with version 4.7.5.1.83.8.263 so a more recent number but the significance of that I don't know!
LaurenB
Fixes: 131
Re: Modem Update
Hi @neilru, can you reply to the ticket I've created here with the requested routers details. If you let us know on here once you've added a reply on the ticket we'll add the details to the account and if you then factory reset the router it should push through an update.
 Lauren Barry
neilru
Re: Modem Update
thanks replied to the ticket
Fixes: 1,601
Re: Modem Update
Thanks for confirming the detail @neilru
I've re-added your router into the hardware management system, could you carry out a factory reset by pushing a paperclip into the reset pinhole at the back for 20 seconds? You should then see the firmware update within a couple of days.
Let us know how it goes.
neilru
Re: Modem Update
thanks, i performed the reset, still awaiting the update to come through
Fixes: 1,484
Re: Modem Update
Moderators Note
This topic has been moved from Fibre to My Router
Fixes: 1,601
Re: Modem Update
Thanks for the update, let us know how it goes over the next couple of days
