Hub One longer length power supply/extension cable
- My Router
- Re: Hub One longer length power supply/extension c...
11-05-2020 11:46 AM
I've read a few other posts with no solution.
Re: Hub One longer length power supply/extension cable
11-05-2020 12:04 PM
@Jrfraser83 Welcome to the forum.
Two obvious solutions.
1. Use a mains extension cable instead.
2. Carefully cut the cable and join in a longer length, making sure that the cores aren't shorted together or crossed over.
11-05-2020 12:37 PM
11-05-2020 12:43 PM
11-05-2020 12:45 PM
13-05-2020 8:45 AM
16-05-2020 11:47 AM - edited 16-05-2020 11:49 AM
This, or something similar could do the job, maybe
Dave
16-05-2020 1:20 PM
As long as it has reasonably thick wire in it, it should be OK.
Remember you are pulling 1-2 Amps through the cable, and if the copper is too thin you might drop a volt or two along a fairly long cable.
16-05-2020 3:45 PM
I already have one of those.. they are only 1.5m ish long. I Need 5m and still dont think that one has 3.1mm Internal as needed
@wisty
It's the diameter pin at the router end I am asking about. Is there an official plusnet technical department who can advise me?. I believe its 3.1mm internal (as mentioned in other forums) but there is only the 3.3mm one I found on the market.
God knows why this hub is the only appliance in the world with this power pin diameter? I have a photo but cant seem to find out how to attach it to here?
16-05-2020 3:52 PM
Zen SOGEA 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
16-05-2020 3:53 PM
How did you measure the plug?
16-05-2020 3:54 PM
16-05-2020 3:56 PM
With a ruler. Have taken a photo but cant add it via my mobile. It's in my public photo album though?
16-05-2020 5:35 PM
The HH 4 & 5 PSU I have here is 5.5mm OD and 3mm ID (measured with a micrometer and pin gauge).
The HH6 is the same. But it's definitely a non standard size.
Its 20 AWG cable so on a 6M length @1amp you will drop about 0.5v
17-05-2020 7:43 PM
Would a long ethernet cable to connect a switch to the router enable you to achieve what you wantby a different route?
- My Router
