Power cable for hub one
laul30515
hi, my power cabke has completely broken, non repairable.. i have tried ordering different sized one of amazon and not one of them fit my plus net hub one router 🙄 does anyone know where I could one that would fit? Please
9 REPLIES 9
Alex
Fixes: 13
Re: Power cable for hub one
Just had a quick search, and not round my sisters at the moment so I can't check our Hub One.
It has the adaptor too as the plug? One suggestion was this (previously mentioned on here).
Fixes: 480
@laul30515
If you go onto Ebay you can buy a Hub One complete with PSU for a few pounds.
Fixes: 1,495
Moderators Note
This topic has been moved from ADSL Broadband to My Router
daveplus
Fixes: 10
Fixes: 480
@daveplus , @laul30515
I don't know if the PSU is the same but this one is incorrectly described. The 2704N is a Hub Zero, not Hub One.
daveplus
Fixes: 10
@Baldrick1
You are right. I should have looked closer.
Apologies
Dave
RadioFox
Unfortunately, despite the electrical specs being the same for the 2704N & Hub One power supplies, the connector is slightly different. The 2704N connector is too small for the Hub One. The model numbers on the 2 supplies are same (S018RM1200150), but the P/N is different (191280375 for the Hub One, and 191262942 for the 2704N).
The Amazon one linked to above looks like it might take a while to arrive. That seller has a customer service address in Dublin, and one registered address in Malta, and another in Jersey.
For £1 more, there is a genuine used one on Ebay. https://www.ebay.co.uk/itm/Sagemcom-12V-DC-1-5A-1500mA-AC-DC-Plug-Adaptor-PSU-Switching-Power-Supply...
Or for another extra £1 (but open to offers), a Hub One complete with all leads. https://www.ebay.co.uk/itm/Sagemcom-Plusnet-Hub-One-Wireless-VDSL-Super-Fast-Router-Modem-Wifi/33366...
RadioFox
There are a few sellers on Ebay who mistakenly call the 2704N a "Hub One". There's no mention of hub zero on my 2704N. Was it just a nickname?
Fixes: 480
@RadioFox
No, that's what Plusnet call it.
Edit
Maybe I am wrong. I might just be me associating the zero with the wireless performance of these out of 10.
