How to change the DNS server setting on a Hub One
Gewitty
Does anyone know how to change the default DNS settings on the Hub One?
I just installed one of these today, having upgraded my line to fibre. However, I can find no way to change the DNS settings using the Hub Manager utility.
I use OpenDNS as my DNS provider because of the significantly enhanced filtering controls and reporting which this service provides.
77 REPLIES 77
SpendLessTime
Fixes: 86
Re: How to change the DNS server setting on a Hub One
I'm afraid that the DNS is locked in the Hub One. Sad
Gewitty
That's unacceptable. I'll have to speak to Plusnet and lodge a complaint. How can they block customers using the DNS service of their choice? The OpenDNS service offers protection which I consider essential when children are using computers on my network. Currently, that security has been removed.
w23
Fixes: 4
Strictly speaking Plusnet don't block customers from using the DNS service of their choice, just their default supplied equipment only works on automatic DNS so sets to the ISP's servers - the same as the BT HomeHub 5 (of which the Plusnet Hub1 is a close copy - same kit, rebranded firmware and casing).  It does seem very restrictive - note the Hub 1 cannot be set to respond to WAN ping either
You can use a router of your own choice as long as it's compatible with the package you're on or you can set DNS on some (possibly most/all) devices directly.
Call me 'w23'
Browni
Aspiring Hero
Fixes: 60
You can use the DNS service of your choice by manually setting it on your devices.
Gewitty
That solution will work OK for all the regular fixed equipment in the building, but it isn't really practical for visitors, especially kids with numerous phones, tablets etc.
Chris
Legend
Fixes: 169
Have you looked in to using our Safeguard service? https://www.plus.net/home-broadband/safeguard/
Gewitty
The Safeguard service covers some of what I've been using with the other DNS provider, and will certainly cover me until such time as I can sort out a long-term solution, which seems to mean buying a third-party router.
DocDelete
Stupid question - it seems that the Hub One has locked DNS server addresses. How do I go about changing this to access the Safeguard DNS addresses?
Chris
Legend
Fixes: 169
You don't need to do anything on the router, if you follow the link I've given previously this will apply Safeguard to your account.
Browni
Aspiring Hero
Fixes: 60
DocDelete
Yep, looked at all of that first. Done as instructed. Hub One is still accessing 212.159.13.50 and 212.159.6.9 - not 213.120.234.42. Have switched off/on, waited two hours etc etc etc
It's not a deal breaker but having wandered around the advanced control panel for Hub One I was a bit mollified to see that 'advanced' means different things to different people Wink
DocDelete
Bump.
Okay, my Hub One, despite waiting days and using several power down/ups, refuses to use the DNS settings for Safeguard. Since there's no way to manually control the DNS settings I guess it's supposed to be done when handshaking with Plusnet on restart - but it's not.
Is this normal? Is Safeguard precluded from people with Plusnet's own supplied hardware?
DocDelete
OK. Have been onto support.
For anyone interested the solution (untried) is this:
Hub One has no manual DNS control.
Handshaking with Plusnet is not changing my DNS settings to the Safeguard ones.
Will at Plusnet says that I have to change the DNS settings for each device that I want to have restricted access.
I can do this. Many people won't be able to.
Problems -
1. Unless I restrict user permissions on each device the DNS settings can be reverted by a savvy user (child)
2. I cannot change the DNS settings on any visiting devices (other kids not from this house) without a lot of hassle
So, in my case (and perhaps many others with Hub One) we have a Plusnet supplied device that cannot effectively use a Plusnet provided service.
I've asked Will to pass on this feedback.
Cheers.
BenSwansea
I wanted to change DNS servers as well to use Pi Hole and increase network speed Sad
