Unknown device keeps attaching itself onto router?!
FIXED- Subscribe to RSS Feed
- My Router
- Unknown device keeps attaching itself onto router?...
13-02-2018 8:03 PM - edited 13-02-2018 8:04 PM
Hi alI.
I really don't know what this device is. It shows up as 'Unknown-01-02-03...'. I disconnected everything from the router by changing the Wifi password. I re-connected with only my phone and that unknown device has somehow connected also. What is going on?
Fixed! Go to the fix.
Re: Unknown device keeps attaching itself onto router?!
13-02-2018 8:28 PM
You could try changing the wifi password in the router (note is down), then you will have to change them in all of your devices which connect via wifi. Unknown, simply means the device is not fully identifying itself.
13-02-2018 8:40 PM
But that unknown device is still there. What on earth could it be? Do you think my router's been hacked or compromised in some way?
13-02-2018 8:41 PM
13-02-2018 8:56 PM
13-02-2018 9:01 PM
13-02-2018 9:08 PM
13-02-2018 9:12 PM - edited 13-02-2018 9:17 PM
Anyone know who or what that is?
Edit: I've just found it may be to do with the Sky box I've got. I can't remember using Wi-Fi to add it on the router but I guess I must have.
13-02-2018 10:37 PM - edited 13-02-2018 10:38 PM
If it works you know it is that successfully accessing your router and is nothing to worry about.
- My Router
