Dreaded DECT Phone maybe....
- My Router
- Dreaded DECT Phone maybe....
11-06-2017 3:31 PM
I've been round at my daughter's this weekend and her whole family complained to me about their internet.
I did a speed test using my phone and got 2.69Mbps down and 0.26Mbps up. Usually it's considerably better as it's a good ADSL2+ line.
She doesn't like the router as it doesn't fit in with her décor sitting as it does on top of a shelving unit in the corner of the living room.
I glanced at the router lights, or I would have done if the router was there but it had been moved to the bottom shelf directly alongside the DECT house phone.
The router stats look ok
Upstream | Downstream | |
Current Rate (Kbps) | 1112 | 18420 |
Max Rate (Kbps) | 1112 | 18208 |
SNR Margin (dB) | 6.9 | 5.7 |
Line Attenuation (dB) | 8 | 21.4 |
Errors (Pkts) | 0 | 0 |
so I'm suspecting the DECT phone.
When I get the chance and my daughter is out of the room I'll relocate the router on top of the shelving unit.
Customer and Forum Moderator. Windows 10 Firefox 102.0 (64-bit (64-bit)
Re: Dreaded DECT Phone maybe....
11-06-2017 3:40 PM - edited 11-06-2017 3:40 PM
I will be interested in the result given that my router is right next to the DECT phone although it is fed by a shielded cable - the router that is
- My Router
