DNS issues
nick67
DNS issues
I have just moved across to Plusnet, the supplied router works fine, but I've connected a Draytek 2860n which has a problem in that a number of sites have DNS issues or they are very slow to load.
Any help much appreciated
3 REPLIES 3
Fixes: 1,605
Re: DNS issues
Hi there and welcome to the community forums.
Have you setup your router to use one of the following pair of DNS addresses?
Primary DNS: 212.159.13.49
Secondary DNS: 212.159.13.50
or
Primary DNS: 212.159.6.9
Secondary DNS: 212.159.6.10
Let us know if you've done that and still have issues so we can try other troubleshooting steps.
nick67
Re: DNS issues
Thanks for the reply, seems that it sorted itself out overnight, whether it was due to the handover from Sky or I changed the firmware, although it was automatically updated I selected another with a different suffix.
Fixes: 1,605
Re: DNS issues
No problems, glad to hear the problems fixed Thumbs_Up
