DNS issues
- My Router
- Re: DNS issues
DNS issues
27-10-2017 3:55 PM
I have just moved across to Plusnet, the supplied router works fine, but I've connected a Draytek 2860n which has a problem in that a number of sites have DNS issues or they are very slow to load.
Any help much appreciated
Re: DNS issues
30-10-2017 1:25 PM
Hi there and welcome to the community forums.
Have you setup your router to use one of the following pair of DNS addresses?
Primary DNS: 212.159.13.49
Secondary DNS: 212.159.13.50
or
Primary DNS: 212.159.6.9
Secondary DNS: 212.159.6.10
Let us know if you've done that and still have issues so we can try other troubleshooting steps.
Re: DNS issues
30-10-2017 1:34 PM
Thanks for the reply, seems that it sorted itself out overnight, whether it was due to the handover from Sky or I changed the firmware, although it was automatically updated I selected another with a different suffix.
Re: DNS issues
30-10-2017 1:45 PM
