Connect to 2.4 ghz on dual band
philji
I have by home hub 6 which is dual band. Just bought a new smart power strip which can only connect to 2.4 ghz...failing to conn e t to do fi. How to ensure it can connect. I have not separated bandwidths assuming devices would find appropriate connection.
2 REPLIES 2
Fixes: 1,600
Re: Connect to 2.4 ghz on dual band
Thanks for getting in touch.
Can you try splitting the 2.4GHz wireless frequency away from the 5GHz letting us know how it goes?
Fixes: 419
It should connect without separating the bands but it would cost nothing to try.
It might help if you told us the make of power strip and what you have done to try to connect it.
