Connect to 2.4 ghz on dual band
- My Router
- Re: Connect to 2.4 ghz on dual band
28-07-2019 6:05 PM
I have by home hub 6 which is dual band. Just bought a new smart power strip which can only connect to 2.4 ghz...failing to conn e t to do fi. How to ensure it can connect. I have not separated bandwidths assuming devices would find appropriate connection.
29-07-2019 9:54 AM
29-07-2019 9:58 AM
It should connect without separating the bands but it would cost nothing to try.
It might help if you told us the make of power strip and what you have done to try to connect it.
- My Router
