BT Smart Hub 2
kerz2201
BT Smart Hub 2
Can I use the Smart Hub 2 without any problems? I have fibre unlimited package. Many thanks.
6 REPLIES 6
Fixes: 419
Re: BT Smart Hub 2
@kerz2201
Yes providing that you follow the Smarthub 6 instructions pinned near the top of this board. Note that you cannot separate the bands on the Smarthub 2 which in my opinion puts them at a disadvantage over the older Smarhub 6 unless you have and need the remote disk.
kerz2201
Re: BT Smart Hub 2
Thank you for your reply. Until a few days ago I was using a HH6 and then the orange light appeared and wouldn't disappear. I had a PN Hub One brand new in the box and got that set up no problem. Should I split the frequencies on that for the time being and replace with another HH6 which are more readily available and cheaper as far as I can see?  Thank you again for your help.
Fixes: 419
Re: BT Smart Hub 2
@kerz2201
If you have no wireless problems the there's no real reason to split the bands. It's just that some devices do not work properly when they're synchronised.
When you say thet your Smarthub stopped working did you look to see why? There has been a few cases where the firmware has been updated by BT and for some reason it has triggered a factory reset. If this is the case then all that you need to do is unplug the DSL cable, re-enter your Plusnet username and password and reconnect.
kerz2201
Re: BT Smart Hub 2
Thank you again. I shall try the HH6 again. I have 2 ethernet cables plugged in should I remove those too, enter username and password then reconnect all cables?  Thanks.
Fixes: 419
Re: BT Smart Hub 2
@kerz2201
There's no need to touch Ethernet cables. It's the DSL connection to the outside world that's key.
If that doesn't work then do your own factory reset and start again from scratch.
kerz2201
Re: BT Smart Hub 2
You were right,  looks like there was a firmware update and it had reset the username etc. Have now got it back up and running.  Thank you very much. The Hub One is back in its box Smiley
