Quick query
thetannery1
Quick query
My internet connection is due to be activated Saturday/Sunday, whilst the phone line is already up and running.  I notice however, that I dont get incoming calls (person calling goes straight to an automated message).  Outgoing calls are made fine though and there is a dial tone (with no line noise).
Will this problem affect/be sorted by the internet activation ?
Wibble!
14 REPLIES 14
Fixes: 307
Re: Quick query
Can you PM me your username?
 Matthew Wheeler
thetannery1
Re: Quick query
Message has been sent!
Wibble!
Fixes: 307
Re: Quick query
Thanks. Your order actually completed today so I've activated your account and you should be able to get online.
With regards to your phone our tests have found a potential fault. We're just getting this looked into further.
 Matthew Wheeler
thetannery1
Re: Quick query
Thanks for that.
Is it an exchange related problem or potentially one at the property ?
Wibble!
thetannery1
Re: Quick query
Unfortunately internet access isn't available - No up/down connection or anything like that.
It does look as though the incoming call problem is going to be a.. problem...
Have organised an engineer to come out next week to try and find where the fault is...
Wibble!
PeeGee
Re: Quick query
Stupid Qn: Have you checked that an outgoing call (to your mobile?) presents the correct caller Id?
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
thetannery1
Re: Quick query
Yes, the outgoing number matches the number given.
Wibble!
thetannery1
Re: Quick query
The main concern will be if it's not an exchange problem, the phone line, as far as I can see goes into a long-abandoned server room with the phone line there not being in great shape, resulting in any non-easy fix being a waste of time and effort...
Wibble!
MattyC
Champion
Fixes: 46
Re: Quick query
Hoping that this is resolved for you tomorrow with your engineer appointment. Are you ok to keep us posted?
Matty
thetannery1
Re: Quick query
Will do
Wibble!
thetannery1
Re: Quick query
So far, it's not going terribly well. The assigned number was different to that given, but that was quickly sorted. However, the poor chap is having to deal with an ancient distribution point and a socket that's knackered, along with dodgy fuses...
Wibble!
thetannery1
Re: Quick query
Got it all up and running after 2 hours.  The chap was very prompt which was great.
The phone socket and line had numerous problems, ranging from the intruder system probably causing problems to the actual socket being broken (someone had taken parts out) and the line not working well anyway.
However, after a bit of jerry rigging around the distribution point and relocating the router, it is all running...
Wibble!
Fixes: 168
Re: Quick query
Sounds like the engineer did a thorough job, glad to hear you're up and running.
 Chris Parr
 Plusnet Staff
thetannery1
Re: Quick query
Yes, he was very good.  This is how it all ended up...
Wibble!
