New Order
Fixes: 118
Re: New Order
@MegMont
Just for information. When you reply to a post you get a line of options at the top. To post an image within the message you choose the one that looks like a retangle with a "mountain" in it.
ClaudiaG23
Fixes: 25
Re: New Order
Hey @MegMont sometimes the Suppliers want to do an engineer visit as the ONT may have failed its health check, when this happens, we have to wait for the engineer visit before taking you live.
The reason for the 2 dates is, you say your services should be active by 23.59 on the day, so we then say you'll have service by the following day. This is normal.
 Claudia Garner
Fixes: 583
Re: New Order
@ClaudiaG23 sorry if I seem sceptical, but this situation seems all too common especially as @MegMont posted earlier regarding the ONT
 I can’t seem to see where to attach the image but it has a green light on for power and PON.
a green PON light indicates a fully functional ONT https://help.business.bt.com/app/answers/detail/a_id/19236/~/what-do-the-lights-on-my-openreach-ont-...
ClaudiaG23
Fixes: 25
Re: New Order
@MisterW  This doesn't mean that it needs a health check with the Suppliers. I was only stating one reason why they would want to get an engineer to visit the property for the installation.
 Claudia Garner
Fixes: 387
Re: New Order
Hopefully, @MegMont has contacted Plusnet, and been given a valid reason for the engineer visit, or has been able to cancel it if it is not required - as seems to be the case here.
Fixes: 583
Re: New Order
@ClaudiaG23 As I understand it, the Plusnet ordering system initially detects that there is an existing ONT at the premises and indicates that no engineer is required i.e a remote activation can be effected. Later in the ordering process , the Openreach system does an automated heath check on the ONT and if it fails , requires that an engineer appt is made. Now, I accept that there ARE reasons why the check can fail e.g ONT not powered up, ONT removed (in error) by previous occupant etc.
However, there does seem to be too many occasions , this seemingly another example, whereby the Openreach tests seem flawed. If there is a working ONT , what other situation would cause an engineer visit to be required ?
As more and more people who already have FTTP change suppliers, this situation is going to get more & more common and if there is a problem in the ordering system, it needs investigating and rectifying.
MegMont
Re: New Order
@jab1 @CaludiG23 @MisterW I spoke to PN this morning and all has been sorted. Engineer visit has been cancelled it was due to the health check failing as I was not aware the ONT had been switched off when placing the order, however, it’s now on and been checked and all is good to go for remote activation. Thank you all for your help 😊
MegMont
Re: New Order
@ClaudiaG23 I spoke to the team this morning and everything is sorted as the engineer is no longer required.
Fixes: 387
Re: New Order
Good to hear you got that sorted - one less thing to have to think about, and easily remedied.
Fixes: 583
Re: New Order
@MegMont glad it was sorted. As a matter of interest, did you get any text from Openreach about the ONT check ?
I thought they sent a text saying 'please ensure that the ONT is connected and powered up' before the health check ?
MegMont
Re: New Order
Hi, no I didn’t. I didn’t even realised they did a health check. It just said before I placed the order that we already had fibre so no engineer would be required.
Fixes: 583
Re: New Order
Thanks, I'm fairly sure it ought to send a text. After all, not many people will bother to have the ONT powered up beforel Openreach come to install UNLESS  they know a test is being done.
@ClaudiaG23 can you confirm if the customer is meant to be sent a message to power the ONT for the health check ?
If not, perhaps this could explain why so many are failing. It then just makes work for support to recheck and/ or a wasted engineer visit by Openreach!!
greygit1
Re: New Order
Just wait for my move. I'm sure it'll be full of fun-and-games.
ClaudiaG23
Fixes: 25
Re: New Order
@MisterW This is something we're already looking into. The ONT shouldn't be turned off, however, this is not clear on our website and again this is something we have raised.
 Claudia Garner
