New Order
MegMont
New Order
I’ve just registered and we have both OpenReach and Virgin cables in the property and it tells us that we don’t need an engineer to come out but I’ve received a text saying they’re coming to attend on 25/10 but then when I log into my account it states activation is the 26/10. Why would an engineer be booked if it stated when I signed up one wasn’t needed? Is this just an error?
28 REPLIES 28
Fixes: 389
Re: New Order
@MegMont Welcome to the forums. Are you currently with Virgin or an ISP who use the OpenReach network?
MegMont
Re: New Order
We are currently with Virgin but we’re with BT before so have both cables. When I signed up it said we don’t need an engineer and on my online account it also says this but I still got a text to say an engineer will be coming out so a bit confused. Also with the dates being different on the engineer text to the activation date on my account log in.
Fixes: 389
Re: New Order
If you are currently with Virgin, Openreach will need to reactivate your BT connection. Are you having an FTTC or FTTP connection?
MegMont
Re: New Order
We are getting FTTP
Fixes: 389
Re: New Order
Ah, so the engineer will need to attend to install the ONT, and they will need to do so and confirm it is working before Plusnrt can activate at their end.
MegMont
Re: New Order
@jab1 I’m still confused because we have the OpenReach port… it’s switched on and the lights are on also. Why would an engineer need to visit because of this? Sorry if I seen a bit dense.
Fixes: 389
Re: New Order
You already have the ONT? When was this installed? There have been occasions when n already installed ONT exists where this information goes astray and BT/OR think one needs installing.
MegMont
Re: New Order
It was installed in 2020/2021. I can’t seem to see where to attach the image but it has a green light on for power and PON.
MegMont
Re: New Order
@jab1 I’ve managed to add the image as a public image on my profile if that helps
Fixes: 389
Re: New Order
If it was installed that long ago, the 'records' glitch I mentioned before applies. I would contact PPN tomorrow and explain thiis to them - it should be possible to remotely activate the service.
MegMont
Re: New Order
Thank you. Who is PPN? Is it just the PlusNet customer number 0345 140 0200?
Fixes: 389
Re: New Order
Sorry - should have been 'PN' - Plusnet - on 0800432 02200
MegMont
Re: New Order
Thank you, I’ll do that tomorrow
Fixes: 389
Re: New Order
@MegMont Sorry - dodgy fingers. The phone number should be 0800 432 0200
